Spacer & Tire Size Question
  • asubimmer
    • 6482
    I might be getting some 17x7 wheels REALLY cheap. What would be a good spacer...20mm? Also what size tire? 205/40/17? Does anyone know the website for the tire size calculator?
  • redcarbon
    • Apr 2005
    • 213
    oh dear. how long have you been here? What's the offset, we can't help you until we know the offset.
    I am not exactly sure the correct 17 inch tire size for our cars, but check out the FAQs for some nice tire calculators or search google for "miata tire calc". I know 16s are 205/50-16. Then that would be 205/45-17, but I know guys running 215/45-17 and 225/40-17, right?
    318is -gone-
    • asubimmer
      • 6482
      cool...thats the site I was looking for...so 225/40/17 would be .4% too slow...spedo says 60 and actually 60.3...pretty good. is 225 too wide for a 7" wide rim?
      haha sorry I ment to put the offset...42...that would help ;)
      • redcarbon
        • Apr 2005
        • 213
        225 will fit on a 7" wide wheel. But you may have a problem with 20mm spacers, giving you et22 final offset. TJ runs 205s on a 16x7 et20 wheel, you may be able to get away with a 225 tire with the 20mm spacer - depending on the tire shape and how low you are. Roll your fenders and it would work, most likely. 15mm would definitely work with 225 tires with no alterations.
        318is -gone-
        • erik325i
          • Jan 2005
          • 3567
          you will want a 15mm spacer for your wheels.
          20mm will work if you don't want to run wide tires. They will rub once you get anything wide.
          215/40-17 is a great size. Good luck finding any 225/40-17s. Only a couple campanies make that size.
          Don't get any tire with a larger rolling diameter (like 215/45-17). It will rub and piss you off.
          -Erik
            • 37833
            ...and buy my 15mm spacers :)
            Grover Beach, California
            BimmerHeads.com
            • asubimmer
              • 6482
              crap....like always the good deals go too fast. I will prob get new wheels this summer though...and if you still have those spacers in the summer I may pic them up ;)
