Whats this?
  • madjurgen
    • May 2005
    • 1203
    Whats this?
    Is that a hubcentric ring on this wheel?
    As time went on, the factory developed the car each year, making it faster, more comfortable, and capable of handling at higher speeds.
    You don’t want this. You want the trickiest, most dangerous, oldest model you can find. Only then can you prove to the world that you’re a man.
  • Jand3rson
    • 37587
    Looks like the back of the wheel to me. Most hubcentric rings don't have cutouts for all the markings on the back of the wheel.
    • madjurgen
      • May 2005
      • 1203
      No, im talking about the ring that isnt rusted.
      • boom-monkey
        • 1104
        That is indeed a hubcentric ring.
        • Digitalwave
          is a poseur
          • 6287
          Josh, a hubcentric ring is a small piece that fits INSIDE the hub of the wheel :tsk:
          RISING EDGE
          • MrK
            • Jan 2006
            • 709
            I think what Eurospeed had in mind was a spacer, in which case he would be correct, they don't come with cutouts like that.
            Back on topic, yes there does seem to be a little hubcentric ring in there.
            This is your M20 on steroids:
            • nkell09
              • Jan 2004
              • 575
              Yep, thats the ring... I had to order them for my Mille miglias, mine had a circlip that had to be removed to pull them out.
              • Jand3rson
                • 37587
                He's right, I had it confused.
                • madjurgen
                  • May 2005
                  • 1203
                  so we the people believe it is indeed a ring?
                  • fretburnr
                    • Jan 2005
                    • 1496
                    Its a centering ring for sure. i have plastic ones for my wheels :o
                    Jay
                    • redcarbon
                      • Apr 2005
                      • 213
                      Yes, there is most definitely a centering ring in there. See immediately inward of the rusted part? There's a gold "C" shaped piece of metal (similar in diameter to a wire coat hanger) that can be popped out and then the centering ring can be pulled out. The gold thing is there to keep the centering ring in.
                      Now you just need the proper centering ring for your hub.
                      318is -gone-
