Wheel size Recommendations..
  • dmahoney12
    • Sep 2013
    • 12
    I would like to put new wheels on my '89 e30 325ix. Right now it has stock suspension but would like to upgrade that soon as well. I would like to know if anyone has suggestions on the correct offset that would be needed when adapters will be used. I have found some on ebay that I like but just don't know enough about wheels and tires to be sure. The more I research, the more I question myself.
    17" - Style 32
    Size = 17x7.5, offset = 41mm FRONT
    Size - 17x8.5, offset = 41mm REAR
    I don't think these will work, but just wanted to make sure. From the research it looks like I will need an offset around 21-25, but just didn't know with the 4x100 to 5x120 adapters.
    Thanks in advance,
    Dave
  • lambo
    Captain Scene Points
    • 10953
    You should be able to achieve those offsets with adapters. The thinnest they offer is 18mm. Get in touch with 8380 Labs and they'll hook you up.
      • 34839
      the 7.5" will fit with an offset between 30-35 and you can use a 225 tire if you can find one with the right profile.
      the 8.5" will be much tougher and you'll be pretty much stuck with a 205 tire or smaller.
      anything much less than ET30 will limit how much tire you can fit. ET25 on a 7.5" wide wheel means a 205 at most. ET20 will rub no matter what, unless your suspension is stock height.
      things are tight back there and up front..
      • dmahoney12
        • Sep 2013
        • 12
        Ok, just wanted to make sure these would work. Thanks in advance! Do I require any spacers? I thought I wanted to be around 35 offset.
        Wheel - 16x7
        Offset - et37
        Tire - 205/45/16
        Thanks,
        Dave
          • 37829
          Wheel - 16x7
          Offset - et37
          Tire - 205/45/16
          Thanks,
          Dave
          Yes that will fit right on the iX. Why such small tires though?
          Classic BMW Specialists
          Grover Beach, CA
          www.BimmerHeads.com
          • dmahoney12
            • Sep 2013
            • 12
            That is what came with the wheels. What would you suggest?
            Sent from my HTC6500LVW using Tapatalk 2
              • 37829
              205/50/16 would be the proper size.
              Grover Beach, CA
              www.BimmerHeads.com
