Best front wheel width?
  • cwatt
    • Oct 2012
    • 275
    This is going to be controversial, I know. I'm hoping some track guys and street guys alike will chime in. I would imagine for track, the wider the better. For street however, I'm not so sure.
    I had 8" before and found them to be uber grippy, but so much so that when you really pushed the car, the back end would sooner swing around than the front end ever start to push. I almost want the front end to start giving me feedback before I loose things.
    thoughts?
    7.5"?
    8"?
    8.5"?
  • IRON-E
    • 16548
    thoughts?
    7.5"?
    8"?
    8.5"?
    Buy a Civic /thread
    @IRON-E30 aka Edwin:D
    • Mr. Tasty
      • Jul 2011
      • 3421
      all-my-wat
      2014 Alpine White 335i MSport
      (Daily Driver)
      Full Mperformance Aero
      KW V2 Coilovers
      VRSF Catless Downpipes
      • getouth
        • Jan 2010
        • 3343
        Personal preference dude!
        FEEDBACK:
        http://www.r3vlimited.com/board/showthread.php?t=316212
        BMWCCA #398608
        IG @yagayo38
        "The Best E30's were built with two camshafts four cylinders and sixteen valves!".
        • ser1992
          • Feb 2013
          • 482
          "could I have a bit more understeer please?"
          -no one ever
          • MrSlacker
            • 2494
            6"
            My Seller/Buyer Feedback
            Performance Aftermarket Parts & Accessories
            • Bglad
              • Jul 2010
              • 562
              bald front tires = problem solved?
              • ser1992
                • Feb 2013
                • 482
                thats unsafe! You forgot to tell him to tire shine the entire surfaces as well
                  • 37834
                  Wheel width decides how much grip the car has?
                  Grover Beach, California
                  BimmerHeads.com
                  • redlightpete
                    • Mar 2012
                    • 266
                    E30s should have balanced handling with the same size wheels and tires front and rear. If you're trying to adjust the handling, you should probably look elsewhere. How worn out are your rear subframe and control arm bushings? These can make the handling really sketchy as the rear wheels can start to toe out under cornering load.
                    • Mr. Tasty
                      • Jul 2011
                      • 3421
                      Originally posted by redlightpete
                      E30s should have balanced handling with the same size wheels and tires front and rear. If you're trying to adjust the handling, you should probably look elsewhere. How worn out are your rear subframe and trailing arm bushings? These can make the handling really sketchy as the rear wheels can start to toe out under cornering load.
                      ftfy
                      (Daily Driver)
                      KW V2 Coilovers
                      • studawg
                        • Nov 2013
                        • 39
                        Originally posted by codyep3
                        ftfy
                        zqyx
                        1988 325i 4dr/5sp Lachssilber Metallic/Black Leather
                        2003 540iT M Sport, Black Sapphire/Black
