I have a set a wheels that are 17x8 and 17x9 +35 offset I wanna know what offset i can run to make the wheel flush with the fender. Some people say i can run 0 on the 8 wide and +5 on the 9 wide. I personlly was going to run +10 all around will that be to sunk tho? Does anyone know?
Trying to make my wheels flush 17x8 and 17x9
Et10 will be sunk in the front on the 8. Et10 on the 9 would be pretty flush out back. I would shoot for et10 out back and et0-5 up front. Preferably et0.
I have my 17x8.5s at Et -13 up front and with camber I was able to make it flush. Et0 would be absolutely perfect up front but don't tell me you want to run a large tire as well because thats not going to happen unless you are like stock height and who would want that?
I would suggest running a 205/40 or a 205/45 on the 8. 205/45 on the 9 for sure. You'll need some stretch out back in order to clear your fenders. Regardless of whether you have an early or a late model.
Shoot me a PM if you would like to talk more about it.
TaylorComment
my 17x9's on the rear are ET20, with a 8mm spacer in there, they are pretty close to the guards and rub a little on the rim protector under full compression. So that's effectively ET12. With 2, 8mm spacers in there it hits on the guard. All this with a 215/45R17 tyre.
Same wheel combination on the front with a 15mm spacer results in the tyre striking the guard at full lock. It's ok to drive around on the road 98% of the time, just really big aggressive bumps or when you drive in and out of driveways with too much lock on will rub on the guards.Just a little project im working on
- http://www.lse30.com -Comment
