Spacer question
  • Jand3rson
    • 37587
    Spacer question
    The new wheels I'm ordering for my car are Mazda Miata fitment, so they're RWD, but the offset is +40mm. What size spacers will I need to fit them?
  • asubimmer
    • 6482
    25mm I would think
    • Jand3rson
      • 37587
      Not that big, I was thinking probably 15-20mm.
      • browntown
        • Jun 2004
        • 3524
        how wide are the wheels? I think 7" wide wheels want a 25mm offset (dont quote me on that), so thats a 15mm spacer.
        • UNHCLL
          • 8790
          They arent RWD.
          No wheel is specific to FWD or RWD.
          This topic is worthless without a wheel diameter and width.
          Its like asking... My car wont start, its blue.... what is wrong?
          Below the radar...
          • Dave
            E30 RAT
            • 11675
            Two in one day. Is there something in the water?
            Current Cars
            2014 M235i
            2009 R56 Cooper S
            1998 M3
            1997 M3
            • Jand3rson
              • 37587
              Originally posted by UNHCLL
              They arent RWD.
              So sorry, Chris. I thought it made a difference. Didn't mean to waste your time.
              They are 16x7.
              • UNHCLL
                • 8790
                16x7...
                shoot for a net offset of 20-25mm
                so either 15 or 20mm spacers will be fine. Also, keep in mind what size tires you'll be running. Mine are 205 on a 15x7, and with unrolled lips (et20), they are almost at the fender lip.
                Below the radar...
                • UNHCLL
                  • 8790
                  How do you plan on accounting for the difference in center bore sizes?
                  54.1 = Miata
                  57.1 = E30
                  Below the radar...
                  • Jand3rson
                    • 37587
                    54.1 = Miata
                    57.1 = E30
                    I've always been told that you could run Miata wheels on an E30. Is this not true? Will these wheels not fit on my car then?
                    And tires will be 205/50.
                    • UNHCLL
                      • 8790
                      Miata centerbore is 54.1mm according to the info I found on google.
                      BMW E30 centerbore is 57.1mm.
                      Obviously, a miata wheel has a smaller centerbore, not allowing it to fully seat on the wheel hub/face. You'd need to either:
                      1) Machine the wheels to have the proper centerbore
                      2) Get custom spacers made
                      3) Buy other wheels.
                      FWIW, Honda Civic (1995 era) have ~56.9mm centerbore, hense why they can be used
                      The EM9's are offered in Civic offset, same pricing as Miata version in 16x7. Order those.
                      Below the radar...
                      • Jand3rson
                        • 37587
                        Awesome, thanks Chris!
                        • Digitalwave
                          is a poseur
                          • 6300
                          Chris, you forgot the fact that almost every aftermarket rim is some sort of universal fitment, and the center bore is probably at least 67mm on those rims. For instance, the Civics my rims were made for don't have a 67mm centerbore but the rims do in order to fit various cars. Hubcentric rings are the savior in this case.
                          RISING EDGE
