Wurth or Einszett paint on Euroweaves?
  • boy412
    • Apr 2013
    • 172
    I just picked up a set of Euroweaves (:)) and am going to refinish them myself. I've read a bit of conflicting information on Wurth vs Einszett spray paints and was hoping to hear from R3V about which works best.
    Both of these companies make a quality product, and I understand that success with either of them is going to depend a great deal on surface prep. Einszett does not make a clear coat so I'm wondering how compatible it is with other clear coats? That is one reason to choose Wurth right there. Presumably their clear works well with their paint.
    Any opinions on which paint I should choose? All four wheels are getting a re-spray so I don't need to match anything. I'm just looking for the product that yields the best results. Or if one is easier to work with that is good to know too.
    Thanks!
    1988 Alpineweiß 325iC
    2003 Audi A4 Avant 1.8T
  • reelizmpro
    • 9558
    I used the wurth silver metallic and clear coat rattlecans and they work well provided you get even coats on the wheels. I would however avoid rattlecans altogether and get them professionally sprayed for the best results if you find a pro to do it for say $35-40 each.
    88 M3 - LACHSSILBER
    89 M3 - ALPINEWEISS II
