will this setup work?
  • NASA144
    • 64
    Looking into 225/45/16 (DirezzaZII) with 16x8 4x100 et20 Slip Streams.
    Will they rub the oem strut housing or rear trailing arm? Not worried about the wells.
    Thanks!
    Instructor, NASA-MA. Chump Racer
  • Mr. Tasty
    • Jul 2011
    • 3421
    nope, should be fine
    2014 Alpine White 335i MSport
    (Daily Driver)
    Full Mperformance Aero
    KW V2 Coilovers
    VRSF Catless Downpipes
      • 37832
      It will be a very nice fit.
      Nice to see somebody going with a man-sized tire.
      Classic BMW Specialists
      Grover Beach, CA
      www.BimmerHeads.com
      • NASA144
        • 64
        Thanks guys!
        To confirm...
        NO spacers needed, right?
        If springs are cut (1-1 1/2 coils) No rub, right?
          • 37832
          No spacers needed. A friend runs the same specs on his late model E30 on GC coilovers.
          Grover Beach, CA
          www.BimmerHeads.com
          • NASA144
            • 64
            schweet... Thanks!
            Any ideas on securing the rear springs when cut?
            The cutting is more for balancing the car vs. lowering. Just concerned the spring will pop out when one of the pig tails are cut out.
            • DER E30
              • Sep 2013
              • 2349
              I'm on a similar set up with GC coils with 7mm and 10mm spacers front and rear, respectively. The 7mm in front is needed on my set up because the spring adjustment collar and tire want to be in the same place...
              My rear springs I can pull out easily when fully extended, but never been a problem.
              -Christian
