help with tire fitment please (no stretch)
  • Wasefi
    • Aug 2011
    • 118
    I plan on getting a set of 16x8 et15 all the way around, also will roll fenders but no pull. I want to run a wide tire and keep it squared throughout all four wheels. The tire size that I am leaning towards is 225/45r16 but I really wanted to know if I could possibly fit a 245/45r16 and not have to worry about fitment issues.
    Just in case your wondering which wheels they are, varrstoen v3
    So to recap essentially I want squared setup, wide tires but not too tall. And fender rolling only no pull
    Thanks in advance.
    Your signature picture has been removed. Refer to the Signature and Avatar Guidelines in The Rules.
    • 37832
    With that width and offset a 225/45 is going to be the most you can fit with rolled fenders.
    Classic BMW Specialists
    Grover Beach, CA
    www.BimmerHeads.com
    • Wasefi
      • Aug 2011
      • 118
      What about if I change my offset? Because the wheels are also available in et25.
        • 37832
        It would help but not sure if it'll work still without some pulling.
        Grover Beach, CA
        www.BimmerHeads.com
        • Danny915
          • Sep 2012
          • 200
          I run 16x7.5 et20 and run 225 all around, got the fenders rolled and had no issue of rubbing or anything
          Sent from my SGH-M919 using Tapatalk
          • IRON-E
            • 16548
            I ran 225s on a 7.5 inch rim before, offset was et20 with a 10mm spacer. Had a light pull and roll for the rear and would still rub when I accelerated hard.
            I could live with that bit of rubbin but, I know alot of other people are annoyed by that.
            Hopefully that helps you for your tire selection, good luck.
            @IRON-E30 aka Edwin:D
            • GAbOS
              • Mar 2012
              • 523
              Here are my 16x7.5's with 225/45 These are at et30 I think. My lips are not rolled and if I went any wider on the offset I would definitely need to roll'em.
              • N2MYE30
                • Oct 2007
                • 5536
                16x7.5
                ~et25
                225/45
                KDWs
                No body mods
                COTM
                • Wasefi
                  • Aug 2011
                  • 118
                  Thanks again for all the help!!! I just want to make sure I have somewhat of enough tire to get the e30 moving when the cammed s52 gets put in.
                  • I8UR911
                    • Jan 2013
                    • 260
                    245/45 would not be right..... too tall of a tire. You'd need a 245/40 or 245/35. I've looked around and can't find anything decent in that size.
                    Sent from my SCH-I535 using Tapatalk
                    • Wasefi
                      • Aug 2011
                      • 118
                      Isn't 225/45, and 245/45 the same as far as height is concerned?
                      • I8UR911
                        • Jan 2013
                        • 260
                        No..... not even close
                        • GAbOS
                          • Mar 2012
                          • 523
                          245/45/16
                          245mm / 45% height of the first number (245mm) / 16" wheel.
                          45% of 245mm is taller than 45% of 225mm.
                          • illest318i
                            • 1472
                            225/45 will be pretty square and look perfect. No pulling required just a flat roll.
                            I'll post pics of mine in a little..
                            IG: @_j.wn
                            • Wasefi
                              • Aug 2011
                              • 118
                              What's the offset on your setup?
