Spacers, if you have 17x7 wheels, offset 38, tires 215 40 R17
  • Maluco
    • Oct 2005
    • 6572
    I need to know once and for all, what range-size of spacers will give me enough clearance from my strut and bring me flush with the fender without risking rubbing.
    - Wheels 17x7
    - Offset 38
    - Tires 215/40 R17
    - I will be installing the Bilstein/H&R package
    I know this topic has been beat to a pulp but I don't have any official way of calculating this right now.
    Thank you.
  • Garageaholic
    Freestyle Fabricator
    • Dec 2005
    • 5204
    15mm - don't forget to get hubcentric
    Recent Rebranding!!
    E30 SM62/S62
    E30 M60 V8
    E30 M30 Big 6!
    Instagram.com/garageaholic
    Youtube.com/garageaholic
    • Maluco
      • Oct 2005
      • 6572
      Is 1/2" (12.7mm) worth it? Or should I just order 15mm ones. This local place has 1/2" hubcentric spacers instock for $40 ea. It jumps up to 1" from those which would be too much...
      • Garageaholic
        • Dec 2005
        • 5204
        noooo. get 15mm
        Recent Rebranding!!
        E30 SM62/S62
        E30 M60 V8
        E30 M30 Big 6!
        • Digitalwave
          is a poseur
          • 6302
          Those would probably keep you from rubbing the strut but it wouldn't look good. Are you buying hubcentric? Because I have never seen hubcentric spacers for that cheap, but H&R's are only a few bucks more really.
          RISING EDGE
          • Maluco
            • Oct 2005
            • 6572
            Ok, so 15mm will keep me from rubbing the strut and get close enough to flushness with the fender to look good, right? and not rub the fender?
            • erik325i
              • Jan 2005
              • 3567
              How would they not look good?
              I think 1/2" would be perfect. 1/2" is roughly 13mm. ET38 with a 13mm spacer brings the total offset to ET25, which is ideal, right?
              If people with an ET40 get 15mm spacers, I don't see what's wrong with getting 13mm spacers for ET38...
              If you only planned on using 195 or 205 tires, then I would say to get a larger spacer to push the wheels closer to the fender. With 215s or larger, try to keep the total offset close to ET25 to prevent rubbing the fender.
              -Erik
              • Maluco
                • Oct 2005
                • 6572
                ah!!!!
                Will the real slim shady please stand up! Actually bro, now that I understand offset and all that shit (minus the tire factor) you make sense, if 40mm et, which is 2mm further inside than a 38mm et, works well with a 15mm spacer, than a 38mm et can take a 15mm perfectly!!!! AH!!!!!! Shit!!!!!
                • Digitalwave
                  is a poseur
                  • 6302
                  It'll work fine but ET18-20 is more ideal looks wise and wouldn't rub with a 215 tire. So you could run 20mm spacers as well.
                  RISING EDGE
                  • Maluco
                    • Oct 2005
                    • 6572
                    Spell that out for me, it's 12:17 here, I've almost finished my 12, and am about to go to the bar because I am out....12.7mm, 15mm or 20mm..... BTW I have a major dip-uphill into my complex/
                    • Digitalwave
                      is a poseur
                      • 6302
                      Are those 1/2" spacers even hubcentric? If not, just forget those. 15 or 20mm will both fit, it's up to you.
                      RISING EDGE
                      • Maluco
                        • Oct 2005
                        • 6572
                        yes, they are hubcentric, you guys made that clear from the get-go:up: so what, 1/2" (12.7mm)? yes?
                        • Maluco
                          • Oct 2005
                          • 6572
                          well, it's sounds like if 15mm, being more flushness than 1/2" (12.7mm) will work than I should go with 15mm.....?
                          • erik325i
                            • Jan 2005
                            • 3567
                            To be perfectly honest, it's just a difference of 2mm... They will both work. You probably won't even be able to tell the difference if you looked at them installed...
                            If you want them to be pushed a couple mm closer to the fender, get 15mm spacers.
                            If you want a little extra spacer to make sure that you won't catch the fender lip, go with the 1/2".
                            -Erik
                            • Digitalwave
                              is a poseur
                              • 6302
                              Dude, just make a god damn choice. Yes, all 3 spacers will work.
                              RISING EDGE
