Offset Question
  • Digitalwave
    is a poseur
    • 6293
    Offset Question
    Would 16x8" ET23 clear the front strut, or does it require a spacer?
    RISING EDGE
  • ak-
    • 12422
    It will clear stock strut, but not the brake's carrier if the outer perimeter on the back of your wheel's hub is thick.
    1991 325iS turbo
    • Digitalwave
      is a poseur
      • 6293
      I guess to complicate things the wheels are E38 Style 5's on an E30 M3 5-lug swapped car. Any idea?
      RISING EDGE
      • ak-
        • 12422
        Okay. If that's anything like my old setup which were the same wheels but redrillled to 4x100 on non-M suspension, it will not clear the brake caliper and a 5mm+ spacer is needed.
        What tire are you going to use?
        You might want a spacer anyways to look nicer.
        /opinion.
        1991 325iS turbo
        • Digitalwave
          is a poseur
          • 6293
          Thanks for the info. Tires will preferably a 225/45-16 Direzza Star Spec. I'm hoping to not have to pull the fenders.
          RISING EDGE
            • 37829
            You will need a 3mm to 5mm spacer to clear the brakes with E30 M3 5 lug from what I remember.
            Classic BMW Specialists
            Grover Beach, CA
            www.BimmerHeads.com
            • Digitalwave
              is a poseur
              • 6293
              Cool, that isn't bad. Thanks Matt!
              RISING EDGE
