Adaptors or fill and redrill?
  • RobE30
    • 959
    The title says it. I found a local wheel shop that will fill and redrill the wheels I want for less $$ than adaptors. They press in a hubcentric ring prior to redrilling and welding the OG holes shut.
    My biggest concern with adaptors is the added ET. I don't want to be forced to run small tires to prevent major rubbing.
    The wheels I want to use are the E38 style 5, 16x8. I'd like to run a 225 tire if possible which is why I'm hesitant to run adaptors.
    09 BMW 328xi touring 6spd
    05 Subaru Outback XT 5spd
    87 BMW 325is
    a few bicycles
    • 34835
    if it's a quality job, fill & redrill any day.
    • RobE30
      • 959
      Sounds good to me. Thanks
      87 BMW 325is
      a few bicycles
      • 808e30325i
        • 537
        F&d mos def!
        • redsubdivisions
          • Feb 2011
          • 1762
          If you go this route, let us know how it goes. I have the same exact wheels and I plan on running the same tire as you.
          1989 325i - 2.7i, Holset H1C, 60lb injectors, whodwho MS-PNP.
          2012 Passat TDI - DD Duty
          2008 GMC Yukon XL Denali - Kiddie hauler/grocery getter
