BBS RX 214 16x7 ET35 Fitment E30
  • OGG-MOSS
    • Sep 2014
    • 8
    Hi guys,
    I have been searching around the forum and google for a definite answer but I can't seem to get one. There is a guy selling a set of BBS RX 214 16x7 locally for around 200$. They are in good shape. He used them on his corrado.
    Wheels come with a set of hubcentric rings of 57.1 mm. I wish to know if I need to run 10 mm spacers, and if yes do they have to be the BBS ones who are hub centric type of spacers, or can I just run them with the rings and a set of regular spacers?
    Also, I have a stock suspension but will soon upgrade for Bilstein/H&R combo. Will they fit on a dropped E30 87 cabrio?
    Thanks in advance
  • OGG-MOSS
    • Sep 2014
    • 8
    Update
    The were like new so I bought them anyway!
    • DER E30
      • Sep 2013
      • 2349
      You should be able to bolt the rears right on, the fronts may be an issue with the strut/spring. You probably will need a 10 mm spacer at least in the front. Alternatively, you could stick a 30 plus mm spacer on there and push them out!
      This is a pretty neat tool to tell you about wheel sizes.
      http://www.1010tires.com/Tools/Wheel-Offset-Calculator#
      -Christian
      • OGG-MOSS
        • Sep 2014
        • 8
        thanks
        Thanks for the tip, I ll be look into it! I am not sure about pushing them out as I do not wish to roll my fenders and Montreal roads look more like Kabul ones nowadays with the legion of potholes swarming around :p
