Why don't Beyern Mesh Rims fit my 325ix?
  • PartyMarty
    • Jun 2015
    • 11
    Why do the Beyern Mesh 17x7 4x100 ET27 rims fit the 325i and not the 325ix???
    Is it the struts? I'm getting a complete ground control coil over system for my ix so will that change the situation?
    I'm totally stuck on those rims so what do I need to do to make them work besides getting an i...or will the ground control conversion solve my problem?
  • fresh_TD
    • Aug 2013
    • 2457
    Because of the offset bro
    Sent from my Samsung Note 4
    '91 318i (Alpine) - daily
    '88 325ix (Zinno) - drive here and there!
    • TimeMachinE30
      • Jun 2014
      • 3749
      Offset.
      ACS S3 Build / Dinan 5 E34
      • PartyMarty
        • Jun 2015
        • 11
        OK guys thanks...but does the offset cause the rim to hit the strut? And does changing my suspension over to the konis ground control uses change that situation. If not, perhaps you guys know what can be done.
        • TimeMachinE30
          • Jun 2014
          • 3749
          Read about offset.
          • reelizmpro
            • 9552
            iX's run a higher offest than other e30's. Coilover Suspension swap isn't going to change that.
            88 M3 - LACHSSILBER
            89 M3 - ALPINEWEISS II
            • mtnbimmer
              • May 2012
              • 73
              Yes
              No
              • AndrewBird
                The Mad Scientist
                • 11898
                The issue is not the strut, it's the fender lip. A lower offset wheel pushes the wheel outward, getting it closer to the fender lip.
                • 320iconvertible
                  • Jun 2015
                  • 36
                  Did you figure it out ? I suggest going with a rim that works. There are a lot of other bad ass rims like tuff bbs inspired ;)
                  Sent from my SM-N910W8 using Tapatalk
