Are adapters bad for racing? or reliability? or anything?
  • wholethingoff
    • Mar 2012
    • 128
    Thats the question.
    You may murder me.
  • ThatOneEuroE30
    • Dec 2013
    • 8626
    Do not use adapters for racing they should only be used on a weekend cruiser and even then are iffy imo. If you wanna run 5 lug do the really 5 lug swap
    1991 318i 4dr slick top
    Mtech 2 turbo restoration
    • burkey001
      • Feb 2011
      • 608
      I have 8830 Labs adaptors on a 318is. I do not trust them at all.
      Seldom drive the car now, will be going back to 4x100.
      88 325is. S54, CSL airbox, Motec M800, Motec C127, Motec PDM15, Stoptech STR, MCS 2 way coilovers, Forgeline wheels, Recaro SPA, Eisenmann, Personal, lots of custom.
      90 318is. As new OEM+, BBS LM, AST 4210 2 way coilovers, Wilwood SL6R/SL4R, Dynaudio, Recaro Experts
      • Mr. Tasty
        • Jul 2011
        • 3421
        using 42 draft adapters. I have never had an ounce of fear in failure. I have taken them on numerous canyon runs and drive decently hard. No issues.
        2014 Alpine White 335i MSport
        (Daily Driver)
        Full Mperformance Aero
        KW V2 Coilovers
        VRSF Catless Downpipes
          • 34844
          canyon runs really have no comparison to track driving.
          • Mr. Tasty
            • Jul 2011
            • 3421
            True, although we have some pretty crazy tight canyons in Arizona. I was mostly defending them about spirited daily driving.
            (Daily Driver)
            KW V2 Coilovers
            • agent
              Vice Grand Pubaa
              • 7960
              Originally posted by kronus
              • wholethingoff
                • Mar 2012
                • 128
                Wait I meant spacers. Mine is a 5 lug swapped but the offset is bad. It apparently would rub on the inside.
                So I got hubcentric spacers.
                Get rid of it all?
                • agent
                  Vice Grand Pubaa
                  • 7960
                  I use spacers and hub rings on one of my sets of wheels which has my track tires on it. It's not preferred, though it works until I decide on and purchase a dedicated set of track wheels.
                  It's been suggested that running spacers will wear out wheel bearings prematurely, though I don't have enough data myself to say for sure.
                    • 34844
                    running spacers won't wear on the wheel bearings any more than running a low offset wheel will.
                    spacers are just fine provided you're also using studs IMO. I wouldn't use them with bolts.
                    • Hooffenstein HD
                      • Nov 2012
                      • 1388
                      Yeah, tracks have nowhere near as many bumps and pot holes.
                      • george graves
                        • 20003
                        I think the point is that you shouldn't be pushing your car that hard on a "canyon run". On a track you will be pushing thing to the limit more-times-then-not.
                        Also, ya know, canyons don't usually have run-off areas and safety barriers. So, yea.
                        Originally posted by Matt-B
                        • straight6pwr
                          • Sep 2004
                          • 3450
                          i've had adapters. regardless of any safety issue that may or may not be present (every claims they are unsafe, but no one has any proof), if you have to ask, you obviously don't trust the idea. also, they are a giant pain the in ass.
                          1)you have to undo double the lug nuts to take everything apart.
                          2)just like regular spacers, sometimes you are going to have to fight them to un-stick them from your hubs.
                          3)stupid offsets
                          summary: put the $300 towards a better set of 4x100 wheels.
                          • e30s50dan
                            • Nov 2008
                            • 2076
                            I've used spacers on my 944 race car for years with no issues. Just make sure you are using good long enough studs and steel nuts.
                            NASA
                            BMWCCA member
                            PCA member 25yrs
                            1991 318IS slick top
                            1997 M3 sedan
                            2001 325CI DD
                            “whoever turns the wheel the least, wins"
                            • nrubenstein
                              • 3148
                              So, the thing about adapters is that you generally have fasteners anchored in aluminum. This is, as a rule, sketchy without a real engineering study.
                              Spacers are fine to a point (and there is no difference in attachment security that I can see between studs and bolts). However, they introduce another opportunity to screw up the wheel alignment on the hubs - vibrations are far more likely with spacers than without.
                              Pushing the wheel centerline out does also alter suspension geometry and bearing load.
                              2002 BMW M3 Alpinweiß/Black
                              1999 323i GTS2 Alpinweiß
                              1995 M3 Dakargelb/Black
                              - S50B32/S6S420G/3.91
                              1990 325is Brilliantrot/Tan
                              1989 M3 Alpinweiß/Black
