17x9 all around. et 22. Rears wont be a problem from what i see, fronts are poking quite a bit. Going to need a 10mm up front also. For those running them, how do they fit? Thinking a 215/40 tire and rolling the fenders. Any insight is appreciated.
Fitting 17x9 in front? Help.
215 tire on a 9" rim is way too narrow. Hell, even a 235 is borderline. A 9" rim is made for a 245 tire. No less.Brake harder. Go faster. No shit.
massivebrakes.com
You'll be fitting a 8" wide tire on an 9" rim which is 10" wide (side to side). If you are into the "stretched look" you'll be happy. Handling? Forget about it. ;-)Brake harder. Go faster. No shit.
massivebrakes.com
Originally posted by Massive Lee View PostYou'll be fitting a 8" wide tire on an 9" rim which is 10" wide (side to side). If you are into the "stretched look" you'll be happy. Handling? Forget about it. ;-)[ETA - E30 Adapters] 5 Lug kit with e46m3 front and e46 325/328i rear brake setup
[ETA - E30 Adapters] - 5 Lug kit | DTM Shifter | DSSR
Transaction Feedback
massivebrakes.com
A little added camber will help too. Get some adjustable plates and set them to 2.5-3 degrees.
1991 LS1 Swapped 318is
Instagram:
https://instagram.com/saltybeast/
LS Build Thread:
https://www.r3vlimited.com/board/for...s-e30-ls1-swap
