Offset Vs. Backspacing?????
  • REVHARD05
    • Sep 2005
    • 250
    what is the difference???? i think i got an i deal... if you have a 6inch wide wheel with 0 offset the surface on whitch the hub mounts to we be directly in the middle of the wheel?? but the same wheel whith the same offset will have 3 inches of back spacing???right
    the reason i am asking is because i lik these wheels
    http://cgi.ebay.com/ebaymotors/Sport...18457062QQrdZ1
    but they are 0 offset???
  • Garageaholic
    Freestyle Fabricator
    • Dec 2005
    • 5204
    for the 15x8, you probably want around 20mm spacers in there if it is a 0mm offset Those wheels will probably stick out past your fenders though, maybe even rub on ur fenders.
    As for the front, what is the offset? If it is indeed 0mm as well, put 20mm in the front as well.
    Remember you have to clear your strut housings on both front/rear.
    Recent Rebranding!!
    E30 SM62/S62
    E30 M60 V8
    E30 M30 Big 6!
    Instagram.com/garageaholic
    Youtube.com/garageaholic
    • wayfast
      • Mar 2005
      • 178
      no
      that would make his overall offset -20, which he would need something like+20 or +25.....
      don't quote me on that tho cause i have no idea what i'm talking about
      • Garageaholic
        • Dec 2005
        • 5204
        Originally posted by wayfast
        no
        That doesn't mean that he doesn't need 20mm spacers to pull the rims away from the shocks.
        Recent Rebranding!!
        E30 SM62/S62
        E30 M60 V8
        E30 M30 Big 6!
          • 34844
          you are wrong, and wayfast is right.
          a lower # puts the wheel further out, so zero in this case (15x8 ) would mean your wheel would be sticking WAY out of the fenders, not anywhere near the strut.
          a higher # means the wheel is closer to the strut, so for an ET40 wheel, yeah he'd need a 20mm spacer (effective offset would now be et20), but with a offset of 0 and a 20mm spacer, the effective offset would indeed be -20, and that would be very very bad..
          • REVHARD05
            • Sep 2005
            • 250
            no one has answered my question yet????? offset VS backspacing???
              • 34844
              I have no idea, nobody uses backspacing on BMW wheels - they all specify an offset. it doesn't matter anyway, those wheels will not fit on your car. even if they did the rears are going to stick out a lot, you'll have to run a massive euro-stretch to pull it off.
              • REVHARD05
                • Sep 2005
                • 250
                what is a "massive euro-stretch"....Nando?????
                • 2002maniac
                  • 4260
                  That is correct.
                  15x8 et0 will be sticking out of the fenders close to an inch. How could spacers help?
                  • Brian D
                    • Mar 2006
                    • 832
                    http://www.rsracing.com/tech-wheel.html There, that should help.
                    Literally 15 seconds Googling, FWIW. Just a thought.
                    Euro stretch is tires that are too narrow for the rims width, so they angle in from the rim edge. Buys you a little extra room.
                    1973 Bavaria
                    • Garageaholic
                      • Dec 2005
                      • 5204
                      u got me. ur right, I was thinking the opposite . lol
                      Recent Rebranding!!
                      E30 SM62/S62
                      E30 M60 V8
                      E30 M30 Big 6!
                      • REVHARD05
                        • Sep 2005
                        • 250
                        :grin: thanks... for answering my questions....so know one thinks these wheels will work on the e30??? what off set do you think the purpleish blue e30 half 3/4 of the way down it running???
                        PS m3fan love the sig
                        • REVHARD05
                          • Sep 2005
                          • 250
                          bumpitty bump bump grind??
