Bassett Steel wheels?
  • delamaize
    • Nov 2013
    • 1464
    I've been looking at new wheels and tires, I need to put more rubber down for all that M60 power. lol
    Anyways, I've been thinking that something like these might be intresting:
    http://www.speedwaymotors.com/Basset...eel,73374.html
    Anyone ever use these on a E30, or have any idea if they will fit, or will I need spacers? It says the offset is 5", But I'm still learning about tire specs and such.
    Dumpster Fire Pilot
  • frshmaestro
    • Mar 2016
    • 121
    • delamaize
      • Nov 2013
      • 1464
      THanks man
      Dumpster Fire Pilot
      • Sail Boat
        • Oct 2016
        • 143
        These guys are making a set designed for the e30
        BMW 2002 E10 FITMENT GT-100 SERIES TWO PIECE STEEL WHEEL CONSTRUCTION. SATIN BLACK POWDER COATED WITH SILVER WET PAINT FACE. SIZE: 15 X 8 OR 15 X 7 SQUARE BACK SPACING 4 X 100 mm. BOLT CENTER 56.1 mm. CENTER BORE 5.12 inch FRONT BACK SPACING 5.12 inch REAR BACK SPACING Wheel Weight: 20 / 18 pounds Wheels are rated @ 1200 pounds IMPORTANT NOTE: FENDERS NEED TO BE ROLLED OR TRIMMED FOR CLEARANCE. IN ORDER TO TUCK IN THE FRONT WHEELS YOU WILL NEED TO USE CAMBER PLATES IF YOU ARE PLANNING TO SLAM THE CAR JUST LIKE WE HAVE IT IN OUR PICTURES.
        Keep in mind that steelies are super heavy. those 16x8's are like 28 lbs.
        1991 325i 4 dr Euro Spec, 5 Speed, 4.10 LSD, Slicktop
        • delamaize
          • Nov 2013
          • 1464
          Thanks, I'll check them out. I'm not too worried about weight, with the M60 under the hood. lol
          Dumpster Fire Pilot
