HELP: 15x8 et20 Tires Rubbing
  • MikeM
    • 583
    So after a lot of research I purchased 15x8 et20 TRM C1's and put 205/55 tires to match new coilovers. I set the car down for the first time today and I am rubbing the struts on both sides...but I also don't want extreme front poke. 5mm spacers?
    Spoiler alert: I'm doing engine work so these height settings are the result of first guesses. There is no engine in the car right now.
    How else have people put 15x8s? I'm not the first person to do this. I'm looking for answers ASAP.
    1990 325i Coupe
    ///PNW e30 CREW
  • e30davie
    • Apr 2016
    • 1788
    got any camber there? You might nees some once you add spacers to stop it rubbing on your guards. Chuck on some something to simulate a spacer see how much you need to get some clearance from the strut. Washes or something between the wheel and hub will do. Then wind on the camber and see if you can get the wheels to "fit". with a 5mm spacer they will end up 15 x 8 +15 which I think will fit with some cambers.
    I have some 15x8 zero offset wheels. Clear the strut fine, but no chance of fitting without some serious front guard bashing. They are in the too hard basket, and thus stacked up in the garage.
    • haaken675
      • Sep 2016
      • 601
      side note, as I see you have fortune auto coils, how was the install? I just ordered a set despite seeing hardly any reviews from e30 owners...
      • mr.
        • Jun 2013
        • 513
        5mm or even 3mm might be enough to clear that
        Some slight camber might be needed if you want to keep the top of the tires inside the fender line
        • MikeM
          • 583
          I went to TireRack and swapped them with the same tire in 205/50. Don't go 205/55 on 15x8 et20 unless you want some serious poke and/or fender rolling and pulling!
          I'll write a review on my project thread after I get a chance to drive on them. So far install was a breeze. Just needed a welder.
          1990 325i Coupe
          ///PNW e30 CREW
          • E30335i
            • Feb 2014
            • 1035
            Very good set up esp since you can choose any spring rates. Def better than the BC’s, Megan’s, etc type of coils.
            • Victell
              • 1082
              Camber has no effect on your rubbing situation. A small spacer should do it.
              • mitchlikesbikes
                • Dec 2013
                • 858
                205/55 and 205/50 will have almost the exact same poke, they're the same width. The 205/55 will just be slightly taller. It makes a slight difference but nothing like what you're implying.
                This is correct, the camber has no effect whatsoever because the knuckle is fixed in reference to the strut tube where it's rubbing. Camber moves this whole assembly from one side to the other.
                IG: @mitchlikesbikes
