Need help cleaning my dirty wheels...
  • Jeans_Vicky
    • Feb 2019
    • 17
    Hey,
    I have a 325i with 16" inch wheels that are really, really, really dirty.
    I need help cleaning it because I am out of idea
    There is those nasty black spots only on the chrome portion of the wheel.
    So first I though it was tar but apparently not.
    I've tried to but some WD40 but did not get rid of it
    Second I have those small weird scratches on the inside of the wheel ( On the chrome ) also no idea how to get rid of it.
    If it's possible I would like not to use some weird chemical that are really toxic
    Anyway if you guys can help me I would really appriciate :D
    SRY posting a vid cause don't know how to post a pic
  • cheffy30
    • Sep 2016
    • 1159
    good ol' elbow grease my friend...
    sent from hell using Tapatalk
    '90 325i sedan daily driven
    '85 325e coupe also a daily
    • Jeans_Vicky
      • Feb 2019
      • 17
      Not if I understand
      Do you mean elbow grease like that
      B. Cumming Elbow Grease Original Lubricant Cream, 15-Ounce https://www.amazon.com/dp/B001BSJ1F0..._qxeKCb8DQHQF3
      • AndrewBird
        The Mad Scientist
        • 11898
        I don't think that is chrome, the aluminum is just polished.
        That said, you may have to sand out the "dirt" as it may be pitting and oxidation.
        I'd start with Purple Power/Super Clean, then move up to oven cleaner, then try muriatic acid if nothing else works. See here:
        https://itstillruns.com/use-muriatic...s-7617081.html
        You can usually buy muriatic acid at hardware stores as it is used in pools to adjust ph and for use in concrete cleaning.
        • Tzantushka
          • Nov 2018
          • 389
          Tricky, as looks like your wheels are painted and polished.
          Start with the most gentle product and work up to more aggressive cleaners
          - regular car wash
          - simple green or other all-purpose cleaner
          - dedicated iron contaminate remover iron-x or sonax
          If that doesn't work - sanding and re-painting/re-polishing
          E30 320i vert
          But daily drive is Volvo V60 Polestar
          • e30davie
            • Apr 2016
            • 1788
            Looks like clear coat is going off to me. Nothing you can do but remove the old clear coat and re-apply clear coat to the entire wheel.
            • Jeans_Vicky
              • Feb 2019
              • 17
              Thx for replies
              Thinking about the iron x method
              Will try it out and come back to you
