Chains for tires?
  • Mastrcruse
    • Sep 2005
    • 5340
    Chains for tires?
    Where can I get the chains that wrap around my tires? I am probably going to get some blizzaks and just in case I would like to have some chains in the trunk for some support when needed. Can some one tell me, do they come in different sizes also?
    Thanks
    DJ
  • kencopperwheat
    King of Kegstands
    • 14396
    You should be able to get them at any tire store. You match them to your tire sizes.
    Originally posted by Gruelius
    • Mastrcruse
      • Sep 2005
      • 5340
      Can I use 195 60 14's?
        • 34844
        certainly.. but with snow tires, you want to go as skinny and tall as possible. really short tires (195/60 is a bit undersized) work just like numerically higher diff ratios; they multiply the torque you put to the ground which makes it easier to spin the tires. if you go with a taller tire (even taller than stock) it will have the same effect as having a wider tire, but you'll also want a skinny section width to cut through the snow. I would at least go 195/65.
