I need 5mil spacers
Ed,
I'd like to see what those 5mm ones look like. Conceptually, it makes no sense to me that they would have a lip on them as they still should sit lower than the end of the hub.Current Cars2014 M235i2009 R56 Cooper S1998 M31997 M3Comment
Did the CR7's need hubcentric rings when you didn't use the spacers? In other words, was the centerbore larger than the E30's hub?
Otherwise, it's physically impossible to have a spacer that has 57.1mm inner bore, and 57mm outer bore. There is simply not enough room. This is what I posted above.Comment
According to this deler, the 5 and 10MM ones (same brand as Tunershop carries) are NOT hubcentric.
Hmmm . . .Current Cars2014 M235i2009 R56 Cooper S1998 M31997 M3Comment
What size tires do you have on there? I have the same wheels as you and with 205/45/16 tires and ET20 effectively I had TONS of room, could easily fit 225's, and I had the same suspension and early car, so what are you worried about?Comment
These guys have all kinda dandy spacers and adapters.
PeaceComment
Not legititmately "worried", just wondering how much clearance I actually have before the fenders and/or struts. Tires are 205/50 Potenza S03's.Comment
Just get 15mm hubcentrics and call it a day. Gives the car a real aggressive stance.Comment
