ebay Spacers
  • Nygdup
    • Jul 2006
    • 418
    ebay Spacers
    Anyone used the 4x100 31mm spacers sold on ebay? Thoughts?
    Where is the best place to buy spacers from (reasonably priced). I have et38 wheels.
  • Van Westervelt
    • 9365
    you want an et7?
    • Nygdup
      • Jul 2006
      • 418
      Not sure. I'm still trying to wrap my head around this whole offset thing.
      Warning... thinking outloud here.
      Stock wheel is et20.
      My wheels are et38, meaning I am 18mm further INTO the wheel well, correct?
      Adding a 31mm spacer would be the same as running an et20 wheel with 13mm spacer. Is that pushed out too far to look good?
        • 34839
        no stock wheel for the E30 is ET20.
        • Nygdup
          • Jul 2006
          • 418
          Then what is the stock offset for bottlecaps?
          • 92 mtechnic cabrio
            • 4907
            a 16x7 ET38 and a 16x8 ET38 wheel has completely different spacing from the hub.
            Just like a stock wheel's 6.5" width and your aftermarket wheel's whatever width will have different offsets as well
            R.I.P 07/01/09 - 04/23/10 :(
            • Nygdup
              • Jul 2006
              • 418
              I need to remember not to post when I'm too tired to think. Ignore this thread! I don't have an offset problem.
              My problem is that the brake caliper is rubbing the inside of the wheel. Changing offset won't fix that. But a small spacer would.
              • defekt
                • 25
                I have a set. good quality, but not hub-centric. these wheels are 17x7 et38, so it should be exactly how your wheels will sit.
