This is a sticky topic.
Quote:
Originally Posted by maniacmatt
Okay this has probably been asked in here before but I don't imagine I'll have much luck finding it.
I need new tires for my Ronal LS' 15x7.5 et25. I was thinking 225/50/15 hankook ventus RS-2's. I am lowered about 1.25'' on the cheesy tokico suspension and my fenders are not rolled.
What do you think am I going to have any rubbing issues? Should I go smaller?
Let's say a guy really wanted the FAT Hankook RS-2 in this size, wheel & offset. Would a 5mm spacer or a +20 wheel and heavily rolled fenders get it in there?This is an interesting issue right now actually. I know of two E30 owners who have tried to run that same tire on that same rim. One (who I know, and trust) had horrible rubbing issues on the front struts, and had to actually throw away the tires. The other won't give me any details, but he alluded to not having any problems.
So, I'd suggest going smaller. Or if you really want 225's, the BFG G-Force Sport is known to work and is honestly a pretty similar tire to the R-S2.Comment
www.gutenparts.com
You'd need to make around 14mm more room in the rear than a stock unmolested fender would have. It's entirely possible with an aggressive enough cut/roll.Assume cut and slightly rolled rears and rolled slightly pulled fronts, can I go 205/40 KDW2 with a 15mm spacer in the front and 25mm spacer in the rear?
Would end up ET 10 front ET 0 rear.
I'm hesistant to do a setup meant for 195/40s as there aren't many available and I have a feeling that size will die soon.
The front is pretty much a cakewalk.Comment
3mm will probably be enough. Run them only on the front, and you don't need longer bolts.
Even with the +25 Ronals, it'll be a tight fit on the rear without fender rolling. May or may not rub depending on suspension.Comment
Thanks for the info, I figured the front wouldn't be bad, but I knew the back would.Need parts now? Need them cheap? steve@blunttech.com
www.gutenparts.com
About 30 minutes per fender. It was easy once the fender got nice and hot. It still rubs a little when I go over big bumps on the freeway but that's about it.
RIP
My new wheels seem to fit funky in my opinion. Here's the specs:
- 4x100
- 15"x7"
- et28
- 195/60R15 tires
- need any other info? is there any?
17 x 9, 245/40, ET ????
Basically I'm thinking of making the Works a flush fit street wheel with a slight stretch, then buying another set of wheels for an Extreme Performance Summer tire.Need parts now? Need them cheap? steve@blunttech.com
www.gutenparts.com
16x7 et15 on h&r cupkit. 87 325is. Should I go with 205 50 16 azenzis or 215 45 16.
Every day I wake up we drink a lot of coffee and watch the CNN
Every day I wake up to a bowl of clover honey and let the locusts fly in.
Lobsterbacks attack the town again
Wrap all my things in aluminum
Beams of darkness streak across the sky
Pink rays from the ancient satellite
Every time I look out my window same three dogs looking back at me.
Every time I open my windows cranes fly in to terrorize me.Comment
