This is a sticky topic.
  • Mystikal
    Wheel Fitment Expert
    • 9602
    #1981
    Originally posted by bmwpower
    Long shot, but I wanted to ask anyway.
    Borbet Type C 16x7.5
    ET30
    205/55/16 cooper touring
    not using spacers
    Q1 - Any other size of tire I can use? Eventually these tires will be replaced. As it is now, the tire is close (maybe like 4-5mm) to the strut tube.
    Q2 - What length studs should I use? 75mm, 90mm, etc?
    For reference:
    As you found out, those will be extremely close to the struts. I know of at least one guy who has pulled them off without spacers (on 205/50/16 tires), and at least one other who had it rubbing constantly. I wouldn't necessarily recommend someone to try it, but I would do it myself.
    The tire is too tall. As others said 205/50 or 225/45 are the correct choices. For the 225 you'd definitely want spacers, even 5mm all around is fine. I can never remember stud length, just search the board for that.
    • Mystikal
      • 9602
      #1982
      Originally posted by Mastrcruse
      Anyone had the Falken Sincera SN 828's? I'm looking for cheap tires to get the car down to texas in. The final price installed is alittle over 270. or any suggestions of cheap tires that won't be too shitty in the rain.
      Never heard of it.
      The ZE-912 is so cheap already, and comes in that size. It's an excellent tire.
      • Mystikal
        • 9602
        #1983
        Just checked turnermotorsport and the 5mm spacer required non-beveled wheel backs. Mine are beveled, even with the hubcentric rings I have on the wheels.
        So which spacers should I go with....or any at all?
        Just read this now.
        Look into the 12.5mm hubcentric spacers I've posted here before. Even with 225/45/16 tires, you'd need the slightest of rear fender rolls, and it would look great.
        • Mystikal
          • 9602
          #1984
          Originally posted by JiXer
          So I am thinking 245/40-17 Ventus Rs2's on bbs 7.5" rims.
          Thoughts?
          No.
          235 is the biggest you'd want. It'll work on the 7.5", but you'll be decreasing performance.
          • Mystikal
            • 9602
            #1985
            Originally posted by Danny
            What size tire would you recommend on 15x6 1/2" rims?
            Could I squeeze 225s on there?
            225 R-comps, sure. Street tires, don't even bother.
            205 is the biggest. Just get something super sticky like RT-615s.
            • Danny
              • 14216
              #1986
              Well I was thinking r-comps/slicks
              Would you go with the kumho v710s?
              • Mystikal
                • 9602
                #1987
                For autox, sure.
                • JiXer
                  • 620
                  #1988
                  Originally posted by Mystikal
                  No.
                  How do you figure?
                  Are you saying 245's on 7.5's lay down less rubber than 235's?
                  J.
                  J. Farina
                  Yeah, thats me kicking up all that dirt!
                  • JiXer
                    • 620
                    #1989
                    Not trying to start arguments or question your expertise, but we have run 215's on 6.5's and they are great.
                    I have even run 225 RA1's on 6" rims and they worked great.
                    Obviously tucked, but wore evenly and stuck like glue.
                    J.
                    J. Farina
                    • Mystikal
                      • 9602
                      #1990
                      How do you figure?
                      J.
                      No.
                      More rubber does not equal more performance; the contact patch will be deformed. Also, "laying down rubber" is not an obvective, as no matter what size the tire is the same area of rubber will be in contact with the pavement, given the same car weight. It will just be a different shape, and when the tire is too wide for the wheel this shape is not optimal and you will LOSE traction.
                      • Mystikal
                        • 9602
                        #1991
                        J.
                        215 what?
                        I'm fully aware of the wider range of options when you use R-comps.
                        • bmwpower
                          • 1556
                          #1992
                          Just read this now.
                          I guess there are no 5mm spacers that will work with beveled wheel backs, eh?
                          Trying to avoid extra expenses if possible. Maybe I should just stick to 205/50-16 without spacers or will that size still need spacers (ie, is it any wider than a 205/55 at the strut tube area)?
                          89 325is track project / 05 x5 / 99 M3
                          E30 stuff for sale | Parts I'm looking for
                          • JiXer
                            • 620
                            #1993
                            215 what?
                            Azenis RT-615 - 215/45-16
                            J. Farina
                            • JiXer
                              • 620
                              #1994
                              No.
                              More rubber does not equal more performance; the contact patch will be deformed. Also, "laying down rubber" is not an objective, as no matter what size the tire is the same area of rubber will be in contact with the pavement, given the same car weight. It will just be a different shape, and when the tire is too wide for the wheel this shape is not optimal and you will LOSE traction.
                              Hmmmm.... Thats not computing in my head.
                              Any good links to something illustrating this?
                              I'm very much a visual learner.
                              J.
                              J. Farina
                              • Mystikal
                                • 9602
                                #1995
                                Some 205s will fit, but not all. It's honestly a crap shoot with how close those wheels are.
                                You can also run a 3mm universal spacer. They're $20 for the pair max, and you don't even need new bolts.
