This is a sticky topic.
  • Psyops
    • Aug 2007
    • 76
    #2071
    How should I set up a set of 17x8 et 15 wheels? Right now they have some 205/45/17s mounted on them, but it's time for new rubber so what's the ideal fitment? Spacers? They're going on an '87 iS w/ bilstein sports and h&r race springs, so there should be plenty of room...
    • BrewCity11
      • Mar 2008
      • 2335
      #2072
      About to order the spacers and studs, just wanted to doublecheck here first.
      Wheels: 15x6.5 ET38
      Tires: 205/50/15
      Suspension: HR Race Billy Sports
      Spacers: 20mm, right?
      Wheels Stud kit: 60mm, right?
      Thanks guys.
      turk@gutenparts.com
      • daniel
        • 6703
        #2073
        Wheels: 15x6.5 ET38
        Tires: 205/50/15
        Thanks guys.
        15 to 20mm spacers, yes. i am not sure about the studs.
        http://instagram.com/dslovn.drives
        • BrewCity11
          • Mar 2008
          • 2335
          #2074
          Thanks Daniel.
          Just going off of a previous post here. He wrote stock bolts are 32mm, plus the 20mm spacer, plus some extra would mean 60mm studs.
          turk@gutenparts.com
          • daniel
            • 6703
            #2075
            Thanks Daniel.
            ok. i wasnt sure what the stock length was, so i didnt want to comment. but then yes, 60mm would work.
            • BrewCity11
              • Mar 2008
              • 2335
              #2076
              Well, after looking at Vorshlag's website, it says their 60mm stud kit is good for up to 10mm spacer, so i ended up ordering the 80mm kit just to be safe.
              turk@gutenparts.com
              • Mystikal
                Wheel Fitment Expert
                • 9602
                #2077
                Originally posted by JonFreyr
                15X8,5 ET10 in front and 15X9 ET00 in rear would be pretty fu**ing sweet. No doubt there !
                I have a similar question, looking at buying 16X8,5 for front and 16X9,5 in the rear but wondering which offset to go for. Front would be ET10 or 15 but wondering what to do about the rears. My car is lowered 60/40 and it´s a Touring (if that even matters). I am a noob when it comes to buying wheels, that being said :) my goal is to avoid using spacers.
                Has anyone here got a setup like the one I mentioned?
                Do the same offset with the rears. It will poke out very slightly more, and will look good. I'g suggest ET15 front and rear.
                • Mystikal
                  • 9602
                  #2078
                  I'd go 215/40/17. Even with early arches and lots of spring/damper strength, you may need a minor rear roll depending on the tire used.
                  • z31maniac
                    • 17566
                    #2079
                    Along ways off but this fall after I recover from the 24v swap I'm thinking of buying another set of wheels as a strictly stretch/street setup and possibly put a DOT R comp on the Works for auto-x/HPDE.
                    I will be running stiffer springs as well, probably 475f/650r or something close.
                    17 x 9 ET 10 - 205/40/17
                    17 x 9.5 ET 10 - 215/40/17
                    I figure that should be about an equal stretch front and rear while still allowing for a hint of stagger'd goodness.
                    Thoughts?
                    www.gutenparts.com
                    • Mystikal
                      • 9602
                      #2080
                      Thoughts?
                      That's extremely aggressive. I'd put them up to ET14, that's about the highest possible to clear the fronts. Even still, that's a really tough fit on the rear. Pulling will be necessary.
                      • theox69
                        • May 2008
                        • 1732
                        #2081
                        How would 16x8.5" et14 all around with 215/40/16 tires fit?
                        This is all with GC coilovers..
                        you can have the keys to my hunk of 20+ year old West German steel when you pry them from my cold dead fingers.
                        • Mystikal
                          • 9602
                          #2082
                          Nicely. May need a very basic roll on the back, but don't bother doing it before trying it out. It'll just be right there with stock fenders.
                          • z31maniac
                            • 17566
                            #2083
                            Good to know, since you can custom order Works, I'd want to get the lowest offset possible for the most dish.
                            www.gutenparts.com
                            • Julien
                              • 7471
                              #2084
                              15x9 et3 rear with 225/50/15... any chance they'll fit without murdering the fenders of my touring? car is on h&r sports
                              Thanks,
                              Julien
                              Build Threads:
                              • Mystikal
                                • 9602
                                #2085
                                Thanks,
                                Julien
                                Hahaha not a chance homeboy.
