This is a sticky topic.
  • Mystikal
    Wheel Fitment Expert
    • 9602
    #2146
    Originally posted by Julien
    what is the size of tire for a set of 17x8 et13? (if possible same OD as OEM)
    Thanks jay,
    Julien
    215/40/17. Just the slightest bit of fender rolling needed.
    • Mystikal
      • 9602
      #2147
      Originally posted by e30polak
      Hey Mystikal, picking up some 17x9 et 37 OZ Superturismos. What size spacer and tires to get near flush fitment, with the beat rubber? I have 4 235/40/17s falken 452s that I'd like to run. I am willing to pull the fenders out, as the lips have already been rolled flat.
      Thanks,
      Chris
      lol, 235s and flush fitment don't usually go together. Definitely be pulling.
      You'd want like 30mm rear and 25mm front spacers to make those close to flush, and just to clear the struts. Severe fender work will be needed to get those tires on afterwards.
      • Mystikal
        • 9602
        #2148
        Originally posted by distorto
        i am planning on using the Ronals i found at the pick-a-part. i will have to use 20mm adapters with them and i will be using IE fender flares to cover them up.
        i tried them with a set of 25mm spacers just to see if i liked them.
        the wheels are 16x8 and will have an offset of -9mm.
        will the IE flares cover them up properly with a 20mm adapter?
        i really like the drop of the h&r cup kit, but i don't think the soft ride would work in houston. should i go with bilsteins and IE stage 3 springs?
        thanks!
        The IE flares add like 1.75" IIRC, so yeah you should have more than enough room. I like the Stage 3's but prefer Konis, just for ride quality. But it's completely up to you.
        • Mystikal
          • 9602
          #2149
          Originally posted by mtechnik
          Hello there,
          What should be a fine inflation pressure on a E34 525i (front/rear) running 235/45R17s ?
          Thanks Jay.
          Holy left field question.
          I really couldn't tell you. The M5 used the same tire, try searching the web to see what the OEM spec for that was.
          • Danny
            • 14216
            #2150
            Jay, how can I fit 245s without fender flares?
            • Mystikal
              • 9602
              #2151
              Perfect offset 17's with 245/35/17 tires.
              You could also do the 245/35/16 Toyo T1-R on 16s, but frankly they're not sticky enough to make it worthwhile.
              • Danny
                • 14216
                #2152
                So... what would the perfect offset be? lol
                I'm just thinking outloud.
                Are we talking 17x9s here?
                • Mystikal
                  • 9602
                  #2153
                  17x8 makes it easier, because of the lack of strut room. But I'll line them out here:
                  17x8 ET26
                  17x8.5 ET20
                  17x9 ET13
                  ...you can see how having the skinner wheel makes fitment 10x easier. Because not only does the wheel get wider, but you have to lower the offset to clear the front struts. Now if you want the 245s just on the back, those offsets can all be raised a bunch and fitment gets easier. More space on the inside back there.
                  And don't worry about pipe dreaming in this thread. I'm positive half of the stuff people have me spec'ing is just for fantasy mod lists, lol.
                  • mtechnik
                    • 6156
                    #2154
                    Ok i'll resume searching under E34 525i. I had already come across some charts for the M5 but i figured there would be different specs because of the weight difference.
                    Thnx for the quick response Jay :up:
                    • AundrezIS
                      • 12
                      #2155
                      I want run a 17 X 7.5 et20 wheel on a 87 325is with IE spring/koni SA setup. What tire do you recommend?
                      • dnguyene30
                        • Dec 2008
                        • 75
                        #2156
                        bbs ra
                        15x6 with et13 will fit my 325is?
                        thanks
                        • whterice
                          • Jan 2009
                          • 258
                          #2157
                          looking at lowering my car with ie3 springs and have a set of 15x8 et20 what size of tire will i need with out rolling? i know 195/50 will work can i go a size larger?
                          • Mystikal
                            • 9602
                            #2158
                            Originally posted by aundrezis
                            i want run a 17 x 7.5 et20 wheel on a 87 325is with ie spring/koni sa setup. What tire do you recommend?
                            215/40/17.
                            • Mystikal
                              • 9602
                              #2159
                              Originally posted by dnguyene30
                              bbs ra
                              thanks
                              Fitment is fine, just make sure they clear the calipers. 195/55/15 or something like that would be good.
                              • Mystikal
                                • 9602
                                #2160
                                195/55/15 is a little taller and will fill the wheelwells better. You should clear with a 205/50/15 by a mm or so, up to you if you want to try it out.
