I looked at the free space inside the wheel arch...
Front: there is about 25-30mm between the shock and the wheel. I guest I could easily run 25mm spacer. The problem is that when I completly turn the wheel to the left (for exemple) the outside edge of the tire is very very close to the firewall edge. in fact, there is some trace of contact... I will have to cut and weld if I want to keep those tire.
Rear: There is about 35mm between the wheel and the trailing Arm and maybe a bit less between the wheel and the shocks. I could also run 25mm spacer easely.
However, since the fenders are already cut and that already ordered my flares, i would like to keep it as wide as possible!
