This is a sticky topic.
  • Mystikal
    Wheel Fitment Expert
    • 9602
    #2461
    Originally posted by shiboujin
    continuing from my other thread
    you mentioned 10+ mm spacers for our cars are basically non existent in hubcentric form. so since even with my 5mm spacers I'm hittin frame, I'm fucked?
    Yep, I have said that. And finally, a manufacturer came through, as the poster after you pointed out.
    • Mystikal
      • 9602
      #2462
      Originally posted by Petebee
      Quick question...can I use the lug bolts from my OEM 14" steelies with OEM bottlecaps? Gonna add some RT-615s and go tear up the cones, but need to make sure the lugs will work.
      Yup.
      • Mystikal
        • 9602
        #2463
        Originally posted by E30SPDFRK
        As an update to this, no problems at all. Fenders are pulled a little though.
        I don't really believe those offsets at all then. My 7" ET20 225 looks more flush than that.
        • Mystikal
          • 9602
          #2464
          Originally posted by Matt-B
          Im looking at getting a 75mm stud kit for stock 4 lug cause im tired of the coroded shit i use now.
          am i good with a 8-10mm spacer on those studs?
          Ill be running e38 style 5s, but mosty weaves
          Yeah sorry, replied to your PM today.
          75mm is a massive stud, I wouldn't recommend it because you probably won't be able to get the caps on the wheels after.
          Even a 60mm stud is enough for up to 15mm spacers.
          • Mystikal
            • 9602
            #2465
            Originally posted by RainierHooker
            OK, I've read through most of the thread that pertains to 15x6.5 wheels...
            Referencing a reply to a question about 15x7 ET38 wheels it was said to go with 205/55 tires with a 20mm Spacer for a flush fit.
            Since my wheels are ET33 by my simple math I should go with 15mm spacers for a flush fit. However for maximum 'drivability' should I go with a 10mm or 12.5mm Hubcentric as shown in the ecstuning link above? I'm not as concerned with the 'flushness' of it all, I would rather have full range of suspension play without having to worry about fender or wheel-well rub since I'm not planning on rolling my fenders...
            -RH
            I've run those same wheels, with the same tires. No spacers needed.
            If you want to push them out a bit, 15mm is perfect. You won't even be close to rubbing, don't worry.
            • z31maniac
              • 17566
              #2466
              I was going to post a thread about this in a few days, glad to see the info here.
              www.gutenparts.com
              • E30SPDFRK
                • 5689
                #2467
                BBS RX 16x7 et35 with a 1" spacer up front and a 2" out back
                They're on an early model, so the back has a bit more room.
                Byron
                Leichtbau
                • evil_twin
                  • Nov 2007
                  • 2965
                  #2468
                  This is a STRETCH... but would a 205/50 fit on a 9" rim?
                  Paypal: vdang5@gmail.com
                  Delta Auto Care
                  2875-C Towerview Road
                  Herndon, VA
                  703.435.1375
                  My Feedback Thread: Evil_Twin
                  • Mystikal
                    • 9602
                    #2469
                    Weird. More pics necessary.
                    • Mystikal
                      • 9602
                      #2470
                      Easily.
                      • evil_twin
                        • Nov 2007
                        • 2965
                        #2471
                        Really? Would it look too goofy? I want to run an 8" rim in the front and a 9" in the rear. I have 205 tires for all around.
                        Delta Auto Care
                        Herndon, VA
                        703.435.1375
                        • dannyg
                          • Mar 2007
                          • 1553
                          #2472
                          17x7.5 et40 will this work? spacers so make them sit flush? what tires?
                          1993 325ic Schwarz/Natur
                          1991 318is Black/Black - Slicktop - Project s52
                          1989 Alpine White/Black M3 S52
                          1988 Henna/Pearl M3 <3
                          • johnwoo
                            • Oct 2007
                            • 613
                            #2473
                            ok need some help. just got the car lowered. and i have keskin k1s. i know about having to run a 3 mm spacers for the car front to clear the strut. i don't like how high the car is and i want to run 205/50/16 instead of 205/45. would that be a problem. i was hoping to run a thicker tire to shorten up my gap some. let me know, thanks. keskins are 16x9 +15 offset
                            edit: or can you guys suggest a thicker tire that would work. im lowered on vogtlands so about 1.7 inches all around.
                            • evil_twin
                              • Nov 2007
                              • 2965
                              #2474
                              195/50 on a 9in. rim? Would that work? I thought I had 205/50s but I didn't
                              Delta Auto Care
                              Herndon, VA
                              703.435.1375
                              • E30Beast2B
                                • 17
                                #2475
                                hey what a thread!! well currently i'm running basketweaves 14" and have been wanting to get something else. Spinning out in the rain on an onramp into the median to I-95 has accelerated my move. I'm on a budget and was thinking of buying a set of 16" sportmax wheels maybe even 17" even though I can't find any 17's with the right offset. will I need to change to different lug bolts if i get the sportmax w/ offset 15?
