This is a sticky topic.
  • z31maniac
    • 17566
    #2776
    16 X 8 ET4, I haz coilovers I can dial in the primo stance.
    195/45 and 10mm up front, 17.5mm out back?
    www.gutenparts.com
    • dinanm3atl
      • Feb 2007
      • 7305
      #2777
      Originally posted by Danny
      I can't remember if I asked this or not.
      16x8 et15 501s with 245/35/16 toyo proxes?
      I doubt it.
      16x8 et20 and running 225.45.16 and it is pretty close with a basic roll. I think I could run a 235 but that might be pushing it.
      Roll it a lot and it would probably work.
      • z31maniac
        • 17566
        #2778
        ^You realize the 245/35 is 1.2" shorter than a 225/45 right?
        www.gutenparts.com
        • theox69
          • May 2008
          • 1732
          #2779
          Originally posted by joonsup
          e30 couple lowered on hr sports and bilsteins.
          will running 16x8 et10 all around wrapped with 215/45s cause issues...esp on the track?
          I have the same setup but my offset is 14, and I'm FLUSH with my front fenders lips and I have no clearance in back, but I'm on coilovers.
          Seeing as how you're on H&R sports, have your fenders rolled, since the springs are soft and you'll be tracking it.
          you can have the keys to my hunk of 20+ year old West German steel when you pry them from my cold dead fingers.
          • joonsup
            • 776
            #2780
            i wonder if 14 and 10 offset makes a big difference. thanks for your input
            • Mystikal
              Wheel Fitment Expert
              • 9602
              #2781
              Ha Ha, no....
              • Mystikal
                • 9602
                #2782
                Answered your PM.
                • Mystikal
                  • 9602
                  #2783
                  This is fitment #37 I've spec'd for you. lol.
                  Without spacers, that's already at the limit for the rear. This isn't taking the ridiculously small diameter into account though, so it will probably clear safely. You'd have to find at least 10mm of space by rolling, which isn't the easiest.
                  • z31maniac
                    • 17566
                    #2784
                    This is for a new car though! What I've seen the 195/45 is 23" so still a touch taller than the popular 215/40 at 22.8"
                    It's probably a bit extreme on the spacers, I may just get them and see where it's at.
                    www.gutenparts.com
                    • e30pwr
                      • Oct 2007
                      • 642
                      #2785
                      alright, just bought a set of 14" et30 wheels. Prime style 239's. realistically how much rubber could fit in the wheel wells? http://www.tirerack.com/tires/tires....omCompare1=yes ???
                      • Stephen
                        Шлем ишака
                        • 10774
                        #2786
                        i already asked about rubber and rolling on my 16x8.5 et13s. If i want to make the rears even with the fronts, how much spacer? And i assume more rolling for more spacer
                        • E30SPDFRK
                          • 5688
                          #2787
                          15-20mm for a low early model is pretty much even
                          Byron
                          Leichtbau
                          • Mystikal
                            • 9602
                            #2788
                            Those will be very close to the front struts, you will likely need a 3-5mm spacer to clear comfortably. Otherwise, you're good to go.
                            • Mystikal
                              • 9602
                              #2789
                              For early arches, I vote 10mm. Maybe 15mm.
                              • NickL
                                • 562
                                #2790
                                17x7 et27 lowered on Ie3.
                                Looking for the ideal tire size so no rolling will be needed. Thanks.
                                1987 325is - S52
