Ok I have tried figuring this out using guides but cant seem to get it right. I found a set of 15x8 gottis with 5x144.3 -13 et. I was thinking of filling and re-drilling or running adapters. Would it even be possible to run adapters? Btw this is on an early body car with rolled and pulled arches
	This is a sticky topic.
 trm c1 15x7 and 15x8
 Thinking of running tr motorsports c1 15x7 in the front with 205's and 15x8 in the back with 225's. Would there be any problems running a setup like this?Comment
 Thought I would throw up some pics of the fitment you guys recommended, I love it, thanks!
 2012 MCSCC/NSSCC CP class champ
 HSAX InstructorComment
 I'm in the process of doing the same, picked up my wheels yesterday. Are you redrilling or are you 5lug? If you're 4 lug we have a lot to talk about haha1989 325is / 2.7, 274 cam, e30 M3 5-lug
 1989 LN106 Hilux / 3.0TD SFA
 1974 2002tii / stock
 2002 IS300 / 5spd LSDComment
 Your wheel ceterline is only 4mm off a stock 15" non-US spec setup. I don't have any ideas as to what your exact issue is, there's just far too many variables to comb through.Question to experts.
 I got this setup (as below in the quote).
 I noticed a bad handling characteristics. Basically when I'm breaking hard from high speeds, the car is wandering, quite abruptly, therefore constant steering input is required while breaking to keep it straight. It just doesn't feel very safe or nice TBH.
 I suspect this is because front wheels centerline is now ~20mm outside (as opposed to stock bottlecaps), and because these tires have much more grip when breaking, I suspect this exerts significantly larger forces on the control arm bushing (I use urethane bushes), and in effect front wheel geometry is forced into toe-out situation under heavy breaking causing the described characteristics ?
 Could anybody comment on my theory ? or perhaps confirm that with similar setup are getting similar behavior ? any other theories or perhaps hints on what to try to fix this issue ? I was thinking maybe solid buschings - not 100% solid but on which the movement is very restricted ?
 Thanks,
 Mops.Comment
 Not even remotely close to working, no matter what you do with them.Ok I have tried figuring this out using guides but cant seem to get it right. I found a set of 15x8 gottis with 5x144.3 -13 et. I was thinking of filling and re-drilling or running adapters. Would it even be possible to run adapters? Btw this is on an early body car with rolled and pulled archesComment
