This is a sticky topic.
  • Mystikal
    Wheel Fitment Expert
    • 9602
    #4036
    Originally posted by EndreM
    What do you guys think about 18x8,5 ET 18 in the front + 18x10 ET 30 in the rear? For a non-M vert.
    May need small (5mm) spacers to clear the inside on the rears, but otherwise it's good.
    • Mystikal
      • 9602
      #4037
      Originally posted by darvo
      For best fitment should I run the 5mm spacers or another size spacer?? I want them flush with the rolled fender.
      With the 245 it should already be past what flush would be on a stock fender. Add the spacer if you want to afterwards.
      • Mystikal
        • 9602
        #4038
        Originally posted by KirkerBezerker
        I would really like to run e34 stock weaves on my 4 lug 325is. Is dis doable and wit wat? jk
        Which method do you prefer, fill and drill or spacers?
        Neither are ideal (fill and drill is putting a lot of trust into the guy doing the machining and the offset of the weaves is already quite low to be running adapters). E34 weaves are 15" anyways, it's a lot cheaper to just buy 15" 4x100 euroweaves.
        • Mystikal
          • 9602
          #4039
          Originally posted by CJG
          I'm don't really like the selection of tires in that size. Would it be ok to go with 205/45 or would those be stretched on a 7.5" wheel?
          That's fine, and it won't look stretched. 205/40 would, though.
          • Mystikal
            • 9602
            #4040
            Originally posted by mayko
            Mystikal,
            I would like to fit some 18x8.5 et50 front and rear, what size adapter do you suggest?
            Flush or wide tires? Early or late car?
            • mayko
              • Dec 2010
              • 13
              #4041
              I have a late model and am planing on running 225/35 tires. I would like to get the wheels closer to flush than the stock offset allows. Currently the car sits on stock suspension, coil overs are on the way. Thanks
              • googone20
                • Oct 2009
                • 116
                #4042
                Would it be better to run 215/35/18's or are the 225/35/18's going to be small enough to give the car a nice stance on coilovers and 18's?
                • darvo
                  • Dec 2010
                  • 407
                  #4043
                  And without?? Will it pass flush?
                  • MaxBell
                    • 1391
                    #4044
                    MiM: 10mm rear spacers, 195/55 tires
                    Diamond: 15x8.5 +13 15x9.5 +13 would be beautiful (if possible). 205/50 and 215/45 tires. This will require a flat fender roll as well as linear springs (coilovers). For unrolled subtract an inch from each wheel and back the tires down to 195/55 and 205/50.
                    My car is lowered about 1.75 inches. The rims come in 16x8, 16x10.
                    I want to do 16" steelies. 16x10 may look dope, but may be a little excessive? Would 15's still tuck with the drop i have, would they be better?
                    What et 16x8 could I do? Got this email when I asked them:
                    We offer the 16x8 with a maximum offset of +12mm. We work in every 1/2" increments or (12mm) down to - 100 mm. The 16x10 is available in a maximum of +25 mm offset down to a - 100 mm also.
                    Bill
                    What size tire would be best for pairing with the rim recommendations? I want a little bit of stretch, but still drive-able. I've been pouring over all the internet resources I can find, but this is all Greek to me.
                    REMEMBER: Be safe and have fun is Rule Number 1.
                    The Epic Unbuild of Clint Eastwood
                    • handysmurf59
                      • 335
                      #4045
                      I want to run 4x100, 16x7.5 et35 RH ALLURAD wheels w/205-45-16 tires on my 1987 325iC that is sitting on a set of cabrio spect H&R sports. I test fitted a wheel and it just rubs the strut tower ever so slightly with the lugs tight. What size spacer do you guys recommend? I don't want to roll the fenders just move the wheel out a little.
                      Thanks,
                      Jason
                      "But the way it deals with bumps and heaves makes you think the shocks are filled with unicorn farts and pixie tears."
                      • dmoney(AB)
                        • 1372
                        #4046
                        alright, im puzzled
                        I have a pair of Brock B1 17x8.5 et 13, they dont clear the stock brakes without a rather large spacer.
                        I see Brock makes the same wheel but with a 35 offset. where will this position the wheel?
                        I've used the offset calculator but I dont understand what they are saying.
                        any help?
                        mtech1/2jzgte/r154/275tire
                        function>form
                        • alpinee30m50
                          • 647
                          #4047
                          I have an early model and am looking at diamond racing steelies, 16x8 up front with 195/45 tires and 16x10 rear with 215/45 tires. Im thinking 0 offset in front but im not sure what offset i should run in the rear. Its gonna be pretty dumped with rolled/pulled fenders and im trying to get it nice n flush, any advice on rear offset or anything else i should know?
                          86 Zinno es
                          M50 inside
                          • Mystikal
                            • 9602
                            #4048
                            25mm front 30mm rear would be perfect. Will need a flat fender roll in the rear; if you get high enough spring rates (say, over 600) and roll the lip flat another 5mm of spacing would be easy.
                            • Mystikal
                              • 9602
                              #4049
                              If you pull the fender arch out enough, it will fit just fine without the spacer.
                              • Mystikal
                                • 9602
                                #4050
                                16x10 won't work without extremely stretch tires and the work that goes with it to make such a setup look good. Probably not for you...
                                16x8 +12 is very nice, match those with 205/45/16 tires and you have a nice setup. Maybe add 5mm rear spacers to even it out a bit, but you will need a fender roll.
