This is a sticky topic.
Mystikal, what tire do you recommend for summer tires on our mini? The car MIGHT see a HPDE, but for the most part it will be street driven. I have the conti DW's on the E28 and they seam ok, but I'm not as impressed with them as I thought I would be.
I'm thinking of running a 215/40/17 size. 225/40/17 would be perfect, but there isn't crap in that size. 235/40/17 won't work with the offset I'm running :(Comment
Good Day, fellas. I'm looking at a set of 15x8's with a +20mm offset. Thinking 205-55-15 tires. I found wheels with the same specs on Tire Rack, they only mention that a 225 tire would require fender rolling. The car is lowered on H&R Springs, unknown if struts are non-stock. From the side, I have 3/4" to 1" of vertical space between top of tire and bottom of fender. Camber looks to be around 2-2.5 degrees up front and 2 or so degrees in the rear.
Questions: Will the wheels contact the struts? Will a stretched tire be enough to avoid more than a mild fender roll?
Apologies if I sound like a noob. I have this crap memorized for my 1st gen Impreza, starting from scratch with my 318is. Right now, i'm on studded snows...in upstate NY, in April. Thanks in advance, everyone.1991 BMW 318is, mild SOLD | 1996 Subaru Impreza Wagon(STi V2 replica), inferno spicyComment
Either one of those is fine. As I suggested originally, I'd recommend 10-15mm spacers in the rear also. This will fit fine with the 205s.Comment
Bridgestone RE-11 is pretty much the ultimate street/track tire. No compromises anywhere.Mystikal, what tire do you recommend for summer tires on our mini? The car MIGHT see a HPDE, but for the most part it will be street driven. I have the conti DW's on the E28 and they seam ok, but I'm not as impressed with them as I thought I would be.
If you're willing to give up a bit of the dry capability for a much lower price tag the Hankook V12 is amazing. Doesn't come in that size last time I checked though, only 205/45 and 215/45.Comment
To your questions: No, and yes. Rear roll only.Good Day, fellas. I'm looking at a set of 15x8's with a +20mm offset. Thinking 205-55-15 tires. I found wheels with the same specs on Tire Rack, they only mention that a 225 tire would require fender rolling. The car is lowered on H&R Springs, unknown if struts are non-stock. From the side, I have 3/4" to 1" of vertical space between top of tire and bottom of fender. Camber looks to be around 2-2.5 degrees up front and 2 or so degrees in the rear.
Apologies if I sound like a noob. I have this crap memorized for my 1st gen Impreza, starting from scratch with my 318is. Right now, i'm on studded snows...in upstate NY, in April. Thanks in advance, everyone.Comment
A little help required... I'm running IE STG3s on Konis, front drop hats, no rear spring pads.
Looking at picking up some 17x8 wheels, just wondering what offset/tyre size would work best for a nice flush fit, maybe a little stretch, minimal guard work (rolling is ok).
TIALast edited by cplagz; 04-13-2011, 05:39 PM.Comment
Currently Active Users Viewing This Thread: 2 (2 members and 0 guests)
DTM190, cplagz+
lol, got the finger hovering over the "order" button?Your signature picture has been removed since it contained the Photobucket "upgrade your account" image.
Originally posted by der affefirst try a finger or 2, you need to have them suck on it first and get it nice and wet to help it slip in.
if she goes for that, astroglide up your pole, have her lay on her stomach and slip it in slowly and bury it to your balls and leave it there until she relaxes. once she is used to it slam that ass like a screen door.Comment
