This is a sticky topic.
  • Mystikal
    Wheel Fitment Expert
    • 9602
    #4576
    Originally posted by Mullet Bullet
    how about 15x8.25 0 offset? will it poke too much
    Yes. I don't recommend 8" and up wheels at 0 offset. Without significant work they look silly.
    • rnw
      • Jun 2011
      • 21
      #4577
      Hi Mystikal,
      please help for tire fitment
      Car: 1991 BMW e30 m40
      S/A : Bilstein
      Lowering Spring : Jammex Sport-kit
      Rims # 01: BBS RS023
      (Original set 8x16 et.24 - 1.5" lip, 6" barrel)
      already change to;
      - front 7.5 x 16 (change original barrel to 5.5")
      offset change to et.18 (plc cmiiw.. )
      - rear 9 x 16 (change original lip to 2.5")
      offset change to et.11 (plc cmiiw.. )
      ? please info what tyre is suitable for this set
      Rims # 02: BBS RS071
      Original set 8x15 et.18 - 2" lip, 5.5" barrel
      but i found this rims is change to 6.5x15 et.37(?) - 0.5" lip, 5.5" barrel
      i want to change the lip, can you help me suggest what lip to choose if i want staggered look for daily use ?
      is it 1.5" front and 2" rear or 1.5" front and 2.5" rear ?
      also what tyre to fit the setting ?
      Thank you
      • noE30
        • Jun 2008
        • 2260
        #4578
        What size adapter/tire size should I run for Corvette salad shooters on a late model e30, if I'm shooting for a flush fit. I've seen varying setups so I wanted your opinion.
        I will be running GC coils as well. I'm not afraid to roll my fenders either as long as its not a ridiculous amount.
        PCD: 5x120.65
        16x8.5 et32
        16x9.5 et38
        Flickr
        @michael.colby on Instagram
        "All he needed was a wheel in his hand and four on the road"
        • e30Rooster
          • Jan 2010
          • 958
          #4579
          so just to be sure 17"x11" et-25 has the same backspacing as stock "Is" basket weaves( or very close to), so Ill have the same clearance as the stock wheel to caliper correct?
          Will this fit with some big fender flairs?
          • Mystikal
            • 9602
            #4580
            Originally posted by rnw
            Hi Mystikal,
            S/A : Bilstein
            already change to;
            205/45 front 225/40 rear. Rolled rear arches. If you're worried about fender work 195/45 front 215/40 rear.
            Thank you
            1.5" front 2.5" rear is nice. It's tough to find tires the right diameter for an even stretch though, I'd suggest 195/50 front 205/50 rear for something close.
            • Mystikal
              • 9602
              #4581
              PCD: 5x120.65
              16x8.5 et32
              16x9.5 et38
              20mm front 25mm rear. 195/45 and 215/40 or 205/45 and 225/40 depending on your desired amount of stretch and willingness to work a roller.
              • Mystikal
                • 9602
                #4582
                Front, rear, or both?
                • e30Rooster
                  • Jan 2010
                  • 958
                  #4583
                  both would be ideal but if i have to settle for only rear then so be it, and if so what is the widest I can go for the front.
                  • rnw
                    • Jun 2011
                    • 21
                    #4584
                    Hi Mystical,
                    Thank you for your suggestion.
                    This is the picture of my old setting
                    front r16x7.5 (195/50) rear r16x9 (205/50)
                    not good setting:
                    I do not worry about fender work, my front and rear fender already rolled.
                    so 205/45 front 225/40 rear...
                    But how about 225/45 on the rear, still rubbing ?
                    • Mfever
                      • May 2007
                      • 1058
                      #4585
                      8mm spacers can be trouble on an E30 as the wheel would have zero or next to zero hub lip to sit on. On the rear though, you'll probably get away with it. Learn to torque the bolts in the proper star pattern prior to lowering the car down and you can lessen/avoid any wobbles.
                      the wheels are 17x8 et 25 do you think it would still be an issue? i heard this specific wheel is not ideal to run a spacer with that size?
                      • Bimmerista
                        • Nov 2005
                        • 5425
                        #4586
                        Wheels: Azev A - et20 16x7.5
                        Tire Desired: N.A
                        Tire Size: N.A
                        Suspension: H&R Sport / Bilstein Sport
                        Chassis: 88 325is
                        I'm inquring about 225/45/16 size tires. Will there be rubbing of any kind? Body is all stock, fenders never rolled. Better bet to go 205/50/16? Mainly for daily driving & hard parking. :D
                        • rnw
                          • Jun 2011
                          • 21
                          #4587
                          Hi Mystical,
                          thank u for this advice,
                          For my consideration please info if:
                          - the front lip change to 2" lip (=> r15x8 et.18)
                          - and the rear with 2.5" lip (=> r15x8.5 et.12)
                          Please advice the tire fitment
                          Thank you..
                          • SilberSurfer
                            • 263
                            #4588
                            Hi,
                            Have a set of staggered BBS RS
                            RS001 15x7 and
                            RS002 15x8
                            What tire size should I run ?
                            Same all around ? Wider in rear?
                            • e30Rooster
                              • Jan 2010
                              • 958
                              #4589
                              Will 17"x11" et-25 have any clearance issues with the insides of the car. Am I correct in assuming that the et-25 on an 11" wide wheel is the same back spacing as a stock wheel?
                              which is roughly 5" correct?
                              • Mystikal
                                • 9602
                                #4590
                                +8 will clear the rear inside. For the front you'd need -15 offset.
