No question, just saying thanks Mystikal :D
	This is a sticky topic.
Limited to 205/50s even with a flat rear fender roll.
And to everyone who posts thank you's, you're very welcome. I'm not an arrogant prick, I promise I read and appreciate all of the kind words. I fail to reply just in the sake of keeping the thread clean..ish.Comment
Upon further looking they're stamped 20 and 22, I just pulled the E31 specs off google. I'm looking to not stretch, I'm only going to be on H&R race so not too low, I'm really hoping to fit the 225/235 setup.For all things 24v, check out Markert Motorworks!Originally posted by mbonanniI hate modded emtree, I hate modded cawrz, I hate jdm, I hate swag, I hate stanceyolokids, I hate bags (on cars), I hate stuff that is slowz, I hate tires.
I am a pursit now.Comment
Hey Jay,
Borbet 16x7.5 et20 and 16x9 et15. what size of tires should i run? do i need spacer for better stance?
i'm thinking 205/45 front & 215/40 rear. lmk your opinion and what brand of tires should i buy.
btw, i'm running IE3 w/ drop hats and koni sport on my late model
Thank you,
thanks for the quick response. assuming no need to roll the fender. looks like it's hard to get 225/40/16. do you have any source? really appreciated :)Comment
Hey I have a 1990 325is (don't know if the late year or IS model is different from other e30s)& I have bbs LM reps with a center bore 73.1mm. They are also 17x8 all around with a 40 offset :/. Im thinking of running a 225/35 all around. Beside hub centric rings, what size spacer (if any) would u recommend? Is it worth trying to make those fit me e30?Comment
For a DD, what wheel size and tires (size and model) do you recommend? I've been thinking of picking up either euroweaves (15x7) or Rota Grids/Rota Slipstreams (16x8/15x8) with probably continental contactsports or michelin pilotsports if they are available for the wheel sizes. What are your thoughts/recommendations? Just remember it's for a DD and I have my "fun" wheels already.
Car is an 89 e30 4 door BTW and suspension is H&R sports with billies and drop hats.2008 335i - n54b30
1991 318i - m52b28
1994 fzj80 - LAND CRUSHERComment
Hey, I just wanted a quick confirmation before I order wheels for my winter setup.
Car: 88' 325 2dr
Susp: Eibach springs + drophats (2"ish)
Tires: 195/60/15 winterforce snows
Im trying to narrow it down between these two (cheap) choices, and I want to just make sure they will be an easy bolt up and look decent with nothing too complicated aside from hub-centric rings and possibly tuner bolts.
Wheel 1) Drag DR-20 15X7 4x100 ET10
Link:http://www.erzperformance.com/DRAG_D...54-100gb10.htm
Wheel 2) Konig Rewind 15x7 4x100 ET20
Link: http://www.ebay.com/itm/15X7-KONIG-R...ht_3049wt_1034
Any concerns, or should these bolt right up?
Thanks in advance, I appreciate it!Comment
Jay,
On a not-slammed late model with H&R OE sport springs (1 inch lower than stock) and rolled fenders, and maybe 1.5 degrees of neg front camber (fixed plates), could I get by with 16X7et25 and 225-50-16? I know they're tall, but I'd be running a lot higher than most on this thread. Thanks in advance.Comment
Hi there, im planing to order a set of Compomotive TH 17x8 and ET could be from 15 and above. So what would be the perfect ET for the front and the rear? And the tyres?
I was thinkin 17x8 ET20 at the front with 205/40
17x8 ET16 at the rear with 215/40
will it fit?
I got already rolled the arches at the rear.
Thanks in advance!!Last edited by arubaru; 11-15-2011, 07:00 AM.
Just for clarification, 17x8 +25(aka apex arc-8s) will fit with h&r races with only mild fender work? what about a 17x9 +20, more fender work, but not too much?
On a late model carsigpicOriginally posted by e30hijinksI move faster than "the speed of light." I'm always connected to my Blackberry and am ready to purchase at a moment's notice. I do not play gamesComment
Stretching is 100% necessary. Even with a 215/40 stretched on all around, you'll be working the rear arches quite a bit to get them to fit.Comment
15mm front 20mm rear spacers with 73-57.1mm hubcentric rings. 215/40/17 tires (225/35 is undersized).Hey I have a 1990 325is (don't know if the late year or IS model is different from other e30s)& I have bbs LM reps with a center bore 73.1mm. They are also 17x8 all around with a 40 offset :/. Im thinking of running a 225/35 all around. Beside hub centric rings, what size spacer (if any) would u recommend? Is it worth trying to make those fit me e30?Comment
Totally up to you. I can tell you what fits, but I have no clue what you like.For a DD, what wheel size and tires (size and model) do you recommend? I've been thinking of picking up either euroweaves (15x7) or Rota Grids/Rota Slipstreams (16x8/15x8) with probably continental contactsports or michelin pilotsports if they are available for the wheel sizes. What are your thoughts/recommendations? Just remember it's for a DD and I have my "fun" wheels already.
Car is an 89 e30 4 door BTW and suspension is H&R sports with billies and drop hats.Comment
