This is a sticky topic.
  • brutus87
    • 6280
    #4831
    Wheel guru, I need your help!
    I found some BBS RS wheels, they are 4 lug 114.3mm +17 offset, can they be filled and re=drilled, and will they work with that offset?
    Thank you so much
    • Deadskittles
      • Jul 2011
      • 140
      #4832
      Help needed on wheel fitment, please and thank you
      If im running 16" wheels with -42 offset what size spacers are needed so that there is no rubbing on the front wheels.
      Thanks!
        • 37828
        #4833
        Thank you so much
        Yes and yes!
        Thanks!
        It would help if we knew the width but you're going to want a 15mm to 20mm spacer for good fitment. The 15mm would be on the safer side for outer tire clearance. Not sure what size tire you plan to run.
        Classic BMW Specialists
        Grover Beach, CA
        www.BimmerHeads.com
        • 325ix
          • Aug 2009
          • 7783
          #4834
          Thanks!
          I am assume you mean +42?
          • schtozo
            • 1455
            #4835
            ^^ of course he should have meant that! -42 plus spacers on an e30 is serious business...
            One of the best threads you will ever read
            http://www.r3vlimited.com/board/showthread.php?t=221813
            Nice trailer of my e30
            http://www.youtube.com/watch?v=TTjtG...e_gdata_player
            If i sold you something please leave feedback here
            http://www.r3vlimited.com/board/showthread.php?t=217142
            • Mystikal
              Wheel Fitment Expert
              • 9602
              #4836
              Originally posted by Eydreeyun
              16x9 et 10, would 205/45/16 tires work?
              Yes, fender roll needed in the rear.
              • Mystikal
                • 9602
                #4837
                Originally posted by FunfGan
                This isn't super urgent but, with fenders flared 2 inches, what would your recommended width/ offset and tire size be? I'd be running 15's and want a slightly undersized tire, on the widest wheel possible. Any suggestions?
                Thanks!
                15x10 -3 with a 225/45.
                • Mystikal
                  • 9602
                  #4838
                  Originally posted by Rustyduktape
                  Will I run into any issues with an 87 325is H&R race, bilstein sports, Euroweaves with 205/50/15 tires?
                  No issues.
                  • Mystikal
                    • 9602
                    #4839
                    Originally posted by mjg23bmw
                    I've been half heartedly searching to find this but haven't come across it yet. Is there a chart or anything that tells what offsets fit e30's without spacers, and then which ones fit with spacers and the size spacer needed-and also a chart for which cars have the same centerbore as e30's?
                    Looking to see if 2004 Sentra's have the same centerbore as e30's (I believe sentra lugs are 4X114, but the wheels I'm looking at are drilled for both 4X114 and 4x100 and came off a 2004 Sentra) The wheels are 15X7 et35 ASA 5 spoke with a center cap with 195/60R15 Blizzaks.
                    Thanks
                    I am the chart, sadly. Those wheels should bolt up to an E30 fine, but front strut clearance will be minimal. B15 Sentra is 66mm center bore and E30 is 57mm so you'll need rings. Related note here's my GF's Spec-V:
                    • Mystikal
                      • 9602
                      #4840
                      Originally posted by jaywood
                      Xxr 16x8 et20
                      Bc coils
                      Stock lug bolts
                      What will I need?
                      If the XXR's require tuner bolts, those. Otherwise, 205/50/16 should just clear without fender work. 225/45/16 with a basic rear roll.
                      • Mystikal
                        • 9602
                        #4841
                        Originally posted by hotrodlincoln
                        Stiffer springs?? What do you suggest??
                        Linear spring-rate coilovers (GC, BC, JOM, etc etc). Something above 500lb/in in the rear.
                        • Mystikal
                          • 9602
                          #4842
                          Originally posted by lbreevesii
                          What is the widest tire i could realistically run on an ARC-8 17x8 on the rear- Fender lips are rolled, and spacers aren't out of the question.
                          245/35/17 is the easy one, but there's no good tires.
                          245/40 is about the maximum without serious fender pulling.
                          • Mystikal
                            • 9602
                            #4843
                            Originally posted by Aerton
                            I have 205 50 16 DWS tires and I was thinking of pickcking up a staggerd set of ESM 002
                            s. My convertible is sitting on Bilstein Sport with H&R sport springs. How streched will the rears be? Is this worth doing? Can't afford new tires as I just bought these. Will they fit, will I have to roll the fenders. Anyone have pictures of this setup?
                            Thanks
                            Tires are too large to work with 16x9s, unfortunately. Maybe with absolute fender hacking but otherwise...nope. Sorry.
                            • Mystikal
                              • 9602
                              #4844
                              Thank you so much
                              You'll have to look at the back pad of the wheels to see if redrilling is feasible. Alternatively if the centerbore isn't too large you could stretch the existing holes...basically, in the end you need to get pics to the shop doing the redrill first.
                              Also, need to know wheel diameter and width.
                              • Mystikal
                                • 9602
                                #4845
                                Thanks!
                                I'll assume +42, but yeah, still need the width.
