This is a sticky topic.
  • mccor023
    • Jul 2011
    • 683
    #4876
    15x7 et42 with 205/60 I know it would nee spacers, but what size and would the tires even work?
    Thanks
    I love that people ask stupid questions so I dont have.
      • 37828
      #4877
      That's one size too tall on the tires. You'd want 205/55 for correct fitment.
      Classic BMW Specialists
      Grover Beach, CA
      www.BimmerHeads.com
      • Fusion
        • Nov 2009
        • 3658
        #4878
        Originally posted by Mystikal
        Yes, 0 offset would be the result. In general, just halve the width you're adding and subtract it from the original offset.
        7" wheel
        Add 1" of lip (25.4mm)
        25.4/2 = 12.7mm
        12 - 12.7 = ~0
        Thank you sir.
        And I should be able to fit a 215/50 maybe 225/45 in there right? No care about fenders, may do flares.
        Not going for stance here, but I want wider tires for track and since I couldn't find any decent 8x15's, I'm going with the OZ Vega 3pc'ers I had lying around.
        Will post results when I glue these babies back together.
        • stegosaurus
          • 367
          #4879
          E36 M3 question.
          What size snow tires can I run with the OEM 17x7 ET47 steelies? Had 205/50R17, but would a 215/50 be ok too? 215/55? I like a meaty sidewall.
          • jaywood
            • Jul 2010
            • 4528
            #4880
            16x8 et25 front
            16x9 et20 rear
            Late model. BC coilovers.
            • Mystikal
              Wheel Fitment Expert
              • 9602
              #4881
              Thanks
              Tires are too tall by a bit, but if you go conservative on the spacers you should only lightly scrub the front wheel well during full steering lock.
              15mm all around.
              • Mystikal
                • 9602
                #4882
                Originally posted by Fusion
                Thank you sir.
                225/45 is an easier fit than 215/50. You will be pulling the fenders or adding flares to make that work.
                • Mystikal
                  • 9602
                  #4883
                  Originally posted by stegosaurus
                  E36 M3 question.
                  You'll likely rub the wheel well at steering lock, but otherwise it should work. 215/50.
                  • Mystikal
                    • 9602
                    #4884
                    Originally posted by jaywood
                    16x8 et25 front
                    16x9 et20 rear
                    Test fit the wheels without spacers first. I have great success with BC's and aggressive wheels on BMWs, but we have yet to install them on an E30. With a stock setup you'd need a 3mm spacer to clear the fronts safely. But I have a hunch that it just might clear the BCs, especially if you didn't go for too long of a spring.
                    As for tires, 205/45 front 215/45 rear for even fitment. 215/45 all around for performance (with rolled rear fenders).
                    • hammoj28
                      • Mar 2004
                      • 92
                      #4885
                      16x8 et10.
                      215/40 Tyres.
                      BC Coil overs.
                      Late Model.
                      thelowcartel: https://www.facebook.com/thelowcartel
                      • Mystikal
                        • 9602
                        #4886
                        Originally posted by hammoj28
                        16x8 et10.
                        215/40 Tyres.
                        BC Coil overs.
                        Late Model.
                        On the knife edge of requiring a rear fender roll. Most likely will, just a flattening of the inner lip.
                        • bannre10
                          • Aug 2011
                          • 18
                          #4887
                          What if i were to get ones that were 6.5 inches wide but still et40? as ive taken half an inch (approx 12.5mm) off the width with the same offset. Would i still need to run spacers?
                          Side note would the setup in the post above mine (16x8 et10) work without spacers?
                          Basically is just like to know what wheels i can run without spacers as id prefer not to run them for safety/illegality reasons.
                          • hammoj28
                            • Mar 2004
                            • 92
                            #4888
                            Thanks for the reply. Rear fender roll it is.:D
                            • mach schnell
                              • Apr 2008
                              • 1059
                              #4889
                              16x8"
                              Et11
                              205 50 16's
                              Late model
                              H&R Race's
                              BMW offset front strut mounts
                              Fender lips rolled, but NOT pulled
                              Fit?
                              • Blackout
                                • Apr 2011
                                • 4125
                                #4890
                                Originally posted by mach schnell
                                16x8"
                                Et11
                                205 50 16's
                                Late model
                                H&R Race's
                                Fit?
                                Yes.
                                What brand and model of tires?
                                Because the thing with different tire brands is, some stretch and some don't even though they are the same size.
                                I am running Gruppe-Gs. Same weel setup. But ET15 Front, ET8 Rear.
                                » PARTS FOR SALE
                                » TRANSACTION FEEDBACK
