	This is a sticky topic.
 +30. An iX can fit everything a standard E30 can (more if you modify the metal fenders underneath the flares). You just need a slightly higher (by 8-10mm) offset.Comment
 SELL ME YOUR E30
 1988 Apline 325iX SOLD
 1999 MINT Lincoln Towncar Pimpin
 My Bike when they shit out :wgaf:Comment
 Due to my new coilovers, I'm looking to run a pair of good performance oriented 205/45/16's on 16x8's in the front of my car.
 Any suggestions for some 205/45's that are less prone to looking super stretched and are a good mix of performance vs value?
 ZF320 | M50 Mani | TRM + 21.5lb Injectors + 3.5in MAF | E36 M3 Rack/Driveshaft | Megan Coilovers | 002R/452's
 In the works: UUC Evo 3/DSSR, JB Racing lightweight Flywheel, Shrick cams, BBK (yet to be determined)
 I NEED A WINGLESS AW TRUNK LID PLEASE PM ME IF YOU HAVE ONE!Comment
 I have 4 17x8.5" m contours for my e36 m3 right now. According to wiki, m coupe/roadster rear wheels are 9" wide. I don't mind rolling my quarters, but how wide of tire can I fit in back? Any pics or precedent?
 Thinking of picking up a set of m contour rears from an m roadster/coupe for my rearsOriginally posted by bluntcan you get me a deal on cases of their (fiji) bottled water? i wash my 02 in that shitComment
 Hey sirs...from Jamaica.
 16 x 8's all around +20, lowered on IE stage 3 springs. i got 15mm spacers for the rear (not sure if these are necessary, willing to ditch)
 wt tires do you recommend, looking for a meaty rear tire.. and something decent for the front to clear the strut tower. 87, 325e. dont intend on rolling
 appreciate it, thanks.Comment
 BBS RS189. Rims measure 15x7.5" and 15x8.5" with ET38. The widths seem odd to me, but whatever i guess. My DFORCE rims measure exactly 15x7.
 Currently there are stretched tires on the BBS rims. On the dforce, im running 205/55-15 Kumhos. I like the look of the current tires, though they probably could be a size smaller for sidewall height (maybe 45's?).
 What should i run on the BBS? The car is sitting on JOM coil overs. Would like to avoid rolling fenders. Seems like the rear there should be plenty of clearance, front im not sure. Any tips are appreciated!
 I am thinking of running a 225/50-15 rear and 205/50-15 front. Little lower profile series than whats on there with more width in the rear (since the rims are wider than what im running)
 How the car sits now:
  Last edited by randomsv650; 08-24-2012, 10:59 AM.Your signature picture has been removed since it contained the Photobucket "upgrade your account" image. Last edited by randomsv650; 08-24-2012, 10:59 AM.Your signature picture has been removed since it contained the Photobucket "upgrade your account" image.Comment
 If I'm running 17 x 8 front and 17 x 9 rear et13 all the way around with a 10mm spacer up front to clear my airbags. What would I do with 17 x 8 et20 all the way around??Comment
 Hey, i got a set of bbs rs's. They are 5x114.3 and 16x7.5 with et35, but i'll be getting 18 or 20 mm adapters (putting the final offset at around et17 to et15) Wondering if they will fit without problems with some 205/45s. Question 2, the wheels right now have a .5 inch lip, and I gotta good deal for two 1.5 inch lips. This would make the rear wheels 16x8.5 but with et -8 (with adapters), how much work would it be to pull off this setup? By the way I'm on h&r cupkit, but will likely be getting some sort of coilover setup in the near future.
 Thanks in advance, hopefully all my math is correct!Comment
