	This is a sticky topic.
 just got some wheels 16x8.5et15 all around with a 205x45 falkin 512. what is the lowest possible offset i could run to make these agressive as possible. ill be rolling my fenders. and will be dumped. thanks dude ! i was thinking et0 all around or -5rear?Comment
 No, but they would be ideal for adapters. Get 30mm adapters for all four corners and you have a great setup.Comment
 Backspacing is for strut clearance and has nothing to do with caliper clearance. 6" of rear backspacing is not the maximum, especially for larger wheel diameters.These will not fit an e30 without modifactions/spacers
 The front would be 6.3" of backspacing. You have about 5.5" MAX to play with before you hit the strut. so you would need a 20 -25mm spacer, stretch and pull. (maybe no pull depending on stretch)
 For reference, Even the ESM 16x8" et20 sometimes does not clear the calliper and that has 5.3" backspace
 The rear would be 6.8" and I know for a fact you cannot have any more than 6" of backspacing in the rear. You might be able to get away with running a 20-22mm spacer but its a tight fit and will probably require stretch and pull as you are now essentially running 9.8"-10" wide with et25Comment
 They're already near ideal to me. Mount them, take measurements, and add spacing as you wish. I've seen the offsets you mention work, but usually with 205/40s and a lot of rubbing.Comment
 IMO 40 series look way to small on 16's :/ so you think i should just keep it around that?Comment
 Ah yes, I should have elaborated the strut and caliper difference, thanks...What is the max backspacing in the rear for a 16" wheel?sigpicComment
 Thanks for the help, is there any advantage to running the 225/45's over the 205/50's as far as grip goes or would their be more roll over on 7" wide? Also these would be used mostly for auto-x.sigpic
 1991 318is S52
 1987 325i Vert
 1991 325i
 2011 e70 X5
 Need Anything E30? -> http://www.gutenparts.com/Comment
 There is some advantage to the wider tire, especially for auto-x, but let me put it this way. A 205/50/16 Dunlop Z1 Star Spec would be faster around most courses than even a 225/45/16 R1R. I'd buy the Dunlops, use the 22mm adapters, and enjoy.Comment
 Any of the following: 175/70, 185/65, 185/70.Comment
