	This is a sticky topic.
 This is why I often try to steer people away from 16x8 +0 wheels. Yeah they're cheap and have a huge lip but they don't actually fit.hey mate, so i asked about what wheels would fit my e30.
 you said 16x8 et25 will be fine.
 i went and got these wheels that are 16x8 et0 as they looked amazing and at a really good price!
 however, the front has way too much poke.. (approx 35mm outside the fender).. the rear is pretty much fine (little bit of poke which looks nice )
 what are my options? if i have any?
 You need additional front negative camber and very small tires.Comment
 hey, I recently had some questions about my 16x9 +30mm gottis. I got the +18mm adapters, which arrives me at 9J +12mm. I went to test fit the fronts, and I am hitting my strut tower. Is there something that is messed up with my suspension? Am I going to need to bump up to like +20ish adapters on the front?2014 Alpine White 335i MSport
 (Daily Driver)
 Full Mperformance Aero
 KW V2 Coilovers
 VRSF Catless DownpipesComment
 also, I am sitting at about perfect in my opinnion fitment. I really don't want to push the wheels out further.2014 Alpine White 335i MSport
 (Daily Driver)
 KW V2 Coilovers
 Chance something (strut housing likely) is bent. Is it like that on both sides? There's many guys on here running 16x9 +12 without issue, it's close but shouldn't touch.hey, I recently had some questions about my 16x9 +30mm gottis. I got the +18mm adapters, which arrives me at 9J +12mm. I went to test fit the fronts, and I am hitting my strut tower. Is there something that is messed up with my suspension? Am I going to need to bump up to like +20ish adapters on the front?Comment
 It's safe. Did you already have a front spring rate set? If not 750lb/in is a good starting point.Comment
 (Daily Driver)
 KW V2 Coilovers
 Sorry I think I meant + !  derp I think I meant + !  derp
 Here the info I have:
 Fronts are 16x9 et32 with a 6.5" back spacing, Rears are 16x10.5 et28 with a 5" backspacing and 4.5" lips
 BUT I need to run 18mm adapters.
 Thanks for your help!Last edited by ballski; 10-16-2012, 01:19 PM.Current Moneypits: e36 m3/4/5 Turbo Techno
 1961 Cadillac deVille bagged - IG @bryang513
