Curious to know if I can run 16x9 +15 all around, just dont know what tire size will close the gap much as possible? Sitting on Jom, no adjusters in the rear
This is a sticky topic.
Hi IM NEW ON THE E30 !! :/ and I need help figuring out what kind of wheels I can put my 1990 BMW 325i E30 bought recently , I do not want anything that looks small or very big, I have about 900 dollars (wheels ) , also what kind of coil overs suspension will be good to buy , i don't need my car for racing or drifting just something that looks cool nice and clean ... thanks if i go 16" what will be a good setup and same if i go 17"
Originally posted by wenbeaver89 View PostOk I have a set of 16x7 rota's that i plan on mounting on an 87 with eibach suspension. wondering what spacers i need to fit these on and what is a good size tire to use? I'd like to get 225/45s. i got a turbo'd m50 so traction is a problem so the bigger the tire i can get under the better. I'm planning on going with the bfg gforce kdw. Also on the wheel it say offset: 40, and i measured the backspacing and its 5 and 9/16! Any input?
Originally posted by IronFreak View PostNeed to run this by the Guru before I make a purchase. I want to put some meat under the car, looking for a wide stance and traction to accommodate my swap. Due to some wrinkles I will be adding flares so making the size fit inside the stock fenders, rolled or not isn;t an issue.
16x9 et 0
265/45r16
in all for corners.
Will I have any fitment issues or need for spacers.
Thanks,
Originally posted by Wrinckled View PostRS017 16x8 ET 62
RS018 16x9 ET 36
& both are 5x130
What size adapters would I need to still be tucking / mildly flush and clear the strut / brake caliper?
I'd greatly appreciate as soon as you can get back to me because the listing for these wheels is up soon.
Originally posted by Mystikal View Post55mm front 25mm rear is about ideal (+7 front +11 rear). 195/45 215/40 would look nice.sigpic
Originally posted by darvo View PostWhat tires I could use using 1.25" fender flares and 1.5" rears, with 17x9 et0 wheels?
Meatier the better....
Guessing 9s in the front too, and what is the ride height? lower you go the more space you lose.
You can run a nice square meaty 245/35/17(603.3mm). The et0 is what hurts having a ton of meat.
I went square setup under guessing they are 9s upfront and that allows you to rotate the tires. If you have coilovers you can tune the height to the fitment.
Those specs keep you within stock sizing overall(195/65/14=609.1mm).Last edited by F34R; 01-26-2013, 03:22 AM.~ Puch Cafe. ~ Do business? feedback ~ Check out my leather company ~
Instagram: @BWeissLeather
Current cars:
~ '87 325 M30B35 swap
~ '87 535
~ 01 540 Msport 6spd
~ '06 X5 4.8is
