This is a sticky topic.
i have 17x8 BBS style 5s filled and drill to 4x100 that ill be putting on my '88 vert. I'm on h&r sports and bilstein sports. ive already decided on 215 40 17 as the tire size. i need a 10mm spacer to clear the front brakes. what size spacer should i get for the rear, 15mm?? also what tire brand/model would you recommend?Comment
I'm really terrible at figuring out the spacing for wheels and what not, but I'm looking at a set of konig remembers 16x7.5 et30. What would be a good tire size, little on the beefy side, for them and what kind of spacing should I use to get 'em nice and flush with the fenders?
FREE BITCOINS!! http://qoinpro.com/71690d1639966bfbf223bf16538cec21
1989 325i - Project/weekend driverOriginally posted by scabzzzzI stand up, pull my dick out, and asked my gf to give me some noggin... Well, she starts laughing at me and I freaked out and ran off and locked myself in a bedroom.
2002 325i - DD
2005 Suzuki SV650 - ToyComment
Deciding on tires already is a problem. Without any spacers at all it will already be on the verge of rubbing. Once spacers are mounted it probably wouldn't roll.i have 17x8 BBS style 5s filled and drill to 4x100 that ill be putting on my '88 vert. I'm on h&r sports and bilstein sports. ive already decided on 215 40 17 as the tire size. i need a 10mm spacer to clear the front brakes. what size spacer should i get for the rear, 15mm?? also what tire brand/model would you recommend?
If you're interested in spacing them out, use 205/40 tires instead. With a rear fender roll you should be able to fit the 10/15mm spacers.Comment
15mm spacers x 4, 205/50/16 tires.I'm really terrible at figuring out the spacing for wheels and what not, but I'm looking at a set of konig remembers 16x7.5 et30. What would be a good tire size, little on the beefy side, for them and what kind of spacing should I use to get 'em nice and flush with the fenders?Comment
Hey Mystikal, I'm looking at doing 245/40/17 Hoosiers on a 17x9 wheel. I would do some bolt-on flares so the outer clearance is not my concern. What offset wheel do I need to clear the strut (GC modified coilovers)
Its nearly impossible to find a reasonaly priced wheel that won't require spacers.
S50'd
Originally posted by TDE30What is this faggy shit I have happened upon?Originally posted by slammin.e28I can always live in a M3. Can't M3 a house.Comment
Need a tire recommendation from ya, street car, daily driver in the summer, new wheel setup is 16x9 et6 front and rear. Looking for a tire that wont have a excessive amount of stretch, would prefer square or a slight stretch. Low on Broadway Static coils with stiff rates and adjustable dampening, have a fender roller so I can do some rolling if needed.
I do have a set of 205/45/16 Falken 512s that are almost new if I can't find a different tire setup, just trying to avoid the excessive stretch the 512s will have..
Thanks!Comment
2002 325i - DD
+10 front will give you enough space. Rears can go as high as +25.Hey Mystikal, I'm looking at doing 245/40/17 Hoosiers on a 17x9 wheel. I would do some bolt-on flares so the outer clearance is not my concern. What offset wheel do I need to clear the strut (GC modified coilovers)
Its nearly impossible to find a reasonaly priced wheel that won't require spacers.Comment
