	This is a sticky topic.
 I bought these and they are sitting in a closet so maybe it's time for me put some rubber on them and I wonder how wide I can go without rubbing or using spacers on my '89 Vert. (I don't like the stretched look)
 Thanks for your help!Life is a bitch and then you drive.
 - Kaotik_LifeComment
 Thought I would see what you think for my new rear setup tire wise - 15x10 +15 wheels going on a late model car with GE coil setup and I was looking at getting some Hankook RS3s in 225/45R15 but they are hard to get in AUS and ive been told they are out of stock for ~2 months.
 I then thought maybe a 225/50R15 would work as I had 225/45R16 on a 16x9 +15 and it was fine... Would probably all come down to how wide the tire i pick actually runs....90 318i M62B44 OBD1
 02 530i Touring (Airlift 3P)Comment
 If they are indeed +23 then 225/45/16s can work without rubbing.I bought these and they are sitting in a closet so maybe it's time for me put some rubber on them and I wonder how wide I can go without rubbing or using spacers on my '89 Vert. (I don't like the stretched look)
 Thanks for your help!Comment
 225/45/15 is what I'd suggest hunting down. 225/50/15 is actually substantially wider than 225/45/16 in section width. On a 10" rim the average 225/50 would measure 10.6" while the 225/45 would be 10.0". That's a big difference for what you would think are equal widths.Thought I would see what you think for my new rear setup tire wise - 15x10 +15 wheels going on a late model car with GE coil setup and I was looking at getting some Hankook RS3s in 225/45R15 but they are hard to get in AUS and ive been told they are out of stock for ~2 months.
 Either way 15x10 +15 is a tough fitment.Comment
 I am planning on Picking up some esm ls reps, Likely to be 15" or 16"what size backspace do I need to Be a direct fit?
 Car is a 87 325i Saloon.Comment
 Hey there!
 Looking at 2 sets of wheels.
 One is 15x7 et16 tires 205/55 and the other is 16x8 et20.
 Will I encounter any rubbing at all with the 15s?
 And with the 16s will that rub at all? What size tire you recommend?
 Oh and will I need spacers on any of the wheels to clear brakes/struts?
 Car: late model with lower arches, lowered on I3 and Konis.
 I really don't want to roll or pull my fenders.
 Thanks!sigpicComment
 Bmw 325ixA Sedan, stock suspension parts.....
 Hello.
 I've been thinking about this summer tires for your car.
 Wheels are 7x17-inch, ET 35
 What kind of tire sizes should put in, generally fit even the wheels roll.
 Do I need a spacer. How about if you put 5mm spacer behind the front is 5mm wider track width
 Thank you for your adviceComment
 Yup. Years ago I ran 225/50 ZE-512s which had an 8.9" SW at +20. Did rub at all. Moved to the same size R-S2s sporting 9.2" SW. Horrible, horrible rubbing so bad the car barely wanted to move.
 That's just 4mm of outside width added. That's why we have the giant thread, every mm counts. :)Comment
 15's won't rub. 16's won't rub with 205/50 tires. Strut clearance is fine but caliper clearance is dictated by spoke shape and not wheel specs. Gotta test fit them if you've never seen them on an E30 before.Hey there!
 Thanks!Comment
 You should be able to use those without spacers, but they will be very sunken into the arches and look poor. I'd suggest 20mm spacers all around with 205/55 or 205/50 tires for the best look and performance.Hello.
 ive been looking at rpf1s any one have any experance with these they are a 16x7 35 will these fit with out spacers or will they look strange with out spacers thanks for the helpComment
