This is a sticky topic.
  • steve68
    • Jan 2013
    • 457
    #6466
    Originally posted by Mystikal
    25mm front adapter, 30mm rear for a flush fitment.
    Great, thanks!! Any ideas for adapter, looked a little last night, did see any,
    And how about a tire recommendation, I don't like that stetched crap! Thanks
    88 M3 Lachsliber glass top, 90 IS project,
    • Mystikal
      Wheel Fitment Expert
      • 9602
      #6467
      Originally posted by nipery
      does 9x17 et 30 rear wheels fit without spacers?
      Yes.
      • Mystikal
        • 9602
        #6468
        You're running 9" wide wheels on a tiny E30. You'll need stretch if you want the tires to roll.
        205/45 or 215/40
        • kronus
          • Apr 2008
          • 13005
          #6469
          I'm trying to figure out if this will ever work
          16x8 et25 rears
          16x7 et13 fronts
          18mm adapters f/r
          early arches, not rolled yet but could be
          what's the meatiest tire size I can go? I'm worried about the fronts sticking out too far, but I have some camber adjustment to play with.
          cars beep boop
          • Mystikal
            • 9602
            #6470
            16x8 et25 rears
            16x7 et13 fronts
            18mm adapters f/r
            195/45 F and 215/40 R with rolled rears. You're right the fronts will be pretty aggressive, but I think with -3.5 camber it's do-able.
            • kronus
              • Apr 2008
              • 13005
              #6471
              aw, 195 is pretty wimpy :(
              I'm not 100% about the wheel measurements, will remeasure them tonight, the seller wasn't sure about the numbers he gave me.
              What effective offset do I want on the fronts to have them flush without -3.5 camber? something more in the 2 degree range would be more preferable, and the wheels have a bit of room to get skimmed.
              cars beep boop
              • Mystikal
                • 9602
                #6472
                i'm not 100% about the wheel measurements, will remeasure them tonight, the seller wasn't sure about the numbers he gave me.
                What effective offset do i want on the fronts to have them flush without -3.5 camber? Something more in the 2 degree range would be more preferable, and the wheels have a bit of room to get skimmed.
                +10
                • salmeronjs85
                  • May 2012
                  • 14
                  #6473
                  Need help, I have 17x8 et20 and 17x9 et25 . What tires would you recommend , it's an m technic so it's lowered . Thanks
                  • bigredguy
                    • 357
                    #6474
                    15x9.5 et -5. How much poke am i looking at outside stock fenders, just for comparison. I know ill need to roll, but im thinking about a slight pull if they poke too much. Also what size tire works well with that. I want stretch to keep the tires inside the fender, but i dont want anything too ridiculous. Also, i am running about -6 degrees of camber in the rear
                    INSTAGRAM @ merlow_
                    • Dommedag
                      • Feb 2013
                      • 26
                      #6475
                      Hello.
                      Looking at fitting Work Equip 01 wheels on my car.
                      1988 325i vert.
                      wanting to put 15x8's on it, just curious what the offset should be on this.
                      -1988 325i Cabrio
                      • boriksh
                        • 111
                        #6476
                        16x8 F 16x9 R
                        Trying to find correct size tire for my 16x8 ET15 (front) and 16x9 ET20 (rear) would 225/45/16 all around tires fit with rears rolled?
                        Fender Roller Rental | RTAB Tool Rental
                        e36 Climate Control Issues?
                        Your ≠ you are
                        You`re ≠ your
                        • Mystikal
                          • 9602
                          #6477
                          No experience with -6 camber, but that's too aggressive IMO.
                          • Mystikal
                            • 9602
                            #6478
                            Originally posted by Dommedag
                            Hello.
                            1988 325i vert.
                            I don't know what they come in, but +22 is nice.
                            • Mystikal
                              • 9602
                              #6479
                              On an early car with stiff spring rates maybe. It'll rub occasionally on a late model.
                              • steve68
                                • Jan 2013
                                • 457
                                #6480
                                205/45 or 215/40
                                Thanks,
