	This is a sticky topic.
 would a 235/40/17 fit under a lowered e30? or would they be too wide?looking for the most tread widht i can fit without having to space the wheels and roll fenders, also what offest do i want? Im looking at enkei rpf1's in 17x7, now do i want a 30 INSET or 35? if neither will work what spacers do i need?Last edited by McDewbie; 04-27-2013, 08:50 AM.Comment
 I'm pretty new here and need advice on wheels. On my 5 lugged e30 (swapped from e36), I want to get 16" style 5s. Currently it has 16" salad shooters. Would the style 5s fit the same? Would they poke out? Would they clear the brakes? Thanks in advance!Comment
 Yes. 17x8 +25 wheels are ideal for fitting 235/40/17s but you do need to roll the rear fenders.would a 235/40/17 fit under a lowered e30? or would they be too wide?looking for the most tread widht i can fit without having to space the wheels and roll fenders, also what offest do i want? Im looking at enkei rpf1's in 17x7, now do i want a 30 INSET or 35? if neither will work what spacers do i need?Comment
 They'll fit flush. You may need 5-10mm front spacers depending on how new your brake pads are. 195/45 is the common tire choice.Comment
 Wait a minute! Are you getting wheels Lambo? ;) About time bud! What wheels are they?
 How flush are you looking to go? et20 is pretty much perfect on a daily e30 that is lowered.~ Puch Cafe. ~ Do business? feedback ~ Check out my leather company ~
 Instagram: @BWeissLeather
 Current cars:
 ~ '87 325 M30B35 swap
 ~ '87 535
 ~ 01 540 Msport 6spd
 ~ '06 X5 4.8isComment
 If all works out I'll be heading back to Colorado with a set of 4x100 OZ Futura's ;) At the moment my friend is running 15mm spacers front and rear with them but they poke a little too much for me. I was thinking of stepping it down to 12.5mm spacers front and rear idk yet.
 Originally posted by SpasticDwarf;n6449866Honestly I built it just to have a place to sit and listen to Hotline Bling on repeat.Comment
 Drop to 10mm and WOW! first set is one of my favorites, make it happen bud.~ Puch Cafe. ~ Do business? feedback ~ Check out my leather company ~
 Current cars:
 ~ '87 535
 ok. i think i understand this stuff mostly.... i found some Rota slips 15x7.5 w a backspacing (measured by owner w tire still on) of 5.5inches. that converts to et32 correct? this will not work w/o spacers correct? or will it just clear??? whats the largest offset thatd clear on a 15x7.5? i want an offset of 25 or 20 but i clist is letting me down. I dont wanna run spacers. I'd rather get a wheel that fits.
 its my DD on hr sports and billies. will probably run a 205. thanks in advanceNow with 2.7i power!!!Comment
 I've done a lot of searching, and I believe I have the right answer. I just want to verify:
 15x8 ET 20, 225/50 on all corners with an early model (1986) will fit with no fender roll or pull?
 Car will be lowered, but not slammed. Dinan springs in the front with Bilstein sports, Bavarian Motorsport rear springs with KYB Gas-a-Just.Comment
