This is a sticky topic.
  • Dommedag
    • Feb 2013
    • 26
    #6481
    Originally posted by Mystikal
    I don't know what they come in, but +22 is nice.
    How exactly is that going to look? is +22 a popular offset for those rims?
    -1988 325i Cabrio
    • McDewbie
      • Apr 2013
      • 10
      #6482
      would a 235/40/17 fit under a lowered e30? or would they be too wide?looking for the most tread widht i can fit without having to space the wheels and roll fenders, also what offest do i want? Im looking at enkei rpf1's in 17x7, now do i want a 30 INSET or 35? if neither will work what spacers do i need?
      • cmcilensek
        • Mar 2013
        • 40
        #6483
        I'm pretty new here and need advice on wheels. On my 5 lugged e30 (swapped from e36), I want to get 16" style 5s. Currently it has 16" salad shooters. Would the style 5s fit the same? Would they poke out? Would they clear the brakes? Thanks in advance!
        • AE86
          • 272
          #6484
          14x8.5 wheel + 205/60r14 tire on late model e30, can it be done? What offsets would I need? Thanks.
          WTB: Diamond Schwartz Hood
          • Mystikal
            Wheel Fitment Expert
            • 9602
            #6485
            Yes. 17x8 +25 wheels are ideal for fitting 235/40/17s but you do need to roll the rear fenders.
            • Mystikal
              • 9602
              #6486
              They'll fit flush. You may need 5-10mm front spacers depending on how new your brake pads are. 195/45 is the common tire choice.
              • Mystikal
                • 9602
                #6487
                +15 to +5 would fit that nicely.
                • lambo
                  Captain Scene Points
                  • 10953
                  #6488
                  16x8.5/9 et24/18 205/45
                  What size spacers should I be looking at?
                  Thanks!
                  • F34R
                    sLaughter
                    • 12385
                    #6489
                    Wait a minute! Are you getting wheels Lambo? ;) About time bud! What wheels are they?
                    How flush are you looking to go? et20 is pretty much perfect on a daily e30 that is lowered.
                    Instagram: @BWeissLeather
                    Current cars:
                    ~ '87 325 M30B35 swap
                    ~ '87 535
                    ~ 01 540 Msport 6spd
                    ~ '06 X5 4.8is
                    • lambo
                      • 10953
                      #6490
                      How flush are you looking to go? et20 is pretty much perfect on a daily e30 that is lowered. You could run a square for a nicer fitment with ease.
                      If all works out I'll be heading back to Colorado with a set of 4x100 OZ Futura's ;) At the moment my friend is running 15mm spacers front and rear with them but they poke a little too much for me. I was thinking of stepping it down to 12.5mm spacers front and rear idk yet.
                      • F34R
                        sLaughter
                        • 12385
                        #6491
                        Drop to 10mm and WOW! first set is one of my favorites, make it happen bud.
                        Current cars:
                        ~ '87 535
                        ~ '06 X5 4.8is
                        • AlphaE
                          • Sep 2011
                          • 503
                          #6492
                          ok. i think i understand this stuff mostly.... i found some Rota slips 15x7.5 w a backspacing (measured by owner w tire still on) of 5.5inches. that converts to et32 correct? this will not work w/o spacers correct? or will it just clear??? whats the largest offset thatd clear on a 15x7.5? i want an offset of 25 or 20 but i clist is letting me down. I dont wanna run spacers. I'd rather get a wheel that fits.
                          its my DD on hr sports and billies. will probably run a 205. thanks in advance
                          Now with 2.7i power!!!
                          • lambo
                            • 10953
                            #6493
                            Drop to and WOW! first set is one of my favorites, make it happen bud.
                            Yeah dropping down to 10mm sounds like a good idea.
                            • mrgraphics
                              • 221
                              #6494
                              I've done a lot of searching, and I believe I have the right answer. I just want to verify:
                              15x8 ET 20, 225/50 on all corners with an early model (1986) will fit with no fender roll or pull?
                              Car will be lowered, but not slammed. Dinan springs in the front with Bilstein sports, Bavarian Motorsport rear springs with KYB Gas-a-Just.
                              • badnerd
                                • May 2008
                                • 65
                                #6495
                                rear 1987 325e... 16x 8.25, 4x100 +0 offset, what will i need to make it work
                                Thanks
