This is a sticky topic.
  • Mystikal
    Wheel Fitment Expert
    • 9602
    #6496
    Originally posted by lambo
    16x8.5/9 et24/18 205/45
    What size spacers should I be looking at?
    Thanks!
    I'd go 5mm front and nothing in the rear.
    • Mystikal
      • 9602
      #6497
      Originally posted by AlphaE
      ok. i think i understand this stuff mostly.... i found some Rota slips 15x7.5 w a backspacing (measured by owner w tire still on) of 5.5inches. that converts to et32 correct? this will not work w/o spacers correct? or will it just clear??? whats the largest offset thatd clear on a 15x7.5? i want an offset of 25 or 20 but i clist is letting me down. I dont wanna run spacers. I'd rather get a wheel that fits.
      its my DD on hr sports and billies. will probably run a 205. thanks in advance
      Never trust people measuring backspacing/offset. Rarely does someone do it properly and dropping hundreds of dollars on that chance is silly.
      • Mystikal
        • 9602
        #6498
        Originally posted by mrgraphics
        I've done a lot of searching, and I believe I have the right answer. I just want to verify:
        15x8 ET 20, 225/50 on all corners with an early model (1986) will fit with no fender roll or pull?
        Car will be lowered, but not slammed. Dinan springs in the front with Bilstein sports, Bavarian Motorsport rear springs with KYB Gas-a-Just.
        Definitely needs a rear roll.
        • Mystikal
          • 9602
          #6499
          Originally posted by badnerd
          rear 1987 325e... 16x 8.25, 4x100 +0 offset, what will i need to make it work
          Thanks
          195/45 tires and fender rolling.
          • badnerd
            • May 2008
            • 65
            #6500
            This is for the back or front? I already have 205/45 up front...
            Was trying to fit a wider rim in the rear with the same 225/45 tires
            • lambo
              Captain Scene Points
              • 10953
              #6501
              So 16x8.5 et 19 will clear the strut for sure?
              • weew379
                • Mar 2013
                • 68
                #6502
                Will they fit? can't find the right answer!
                I have Borbet type B 16x9 ET15. what tire size and brand should I run with out rolling my fenders ? I have 8 mm spacers all around!. my car is still stock right now but planning to lower it.
                • crime1
                  • Jan 2013
                  • 45
                  #6503
                  It will rubbs/touch the wheel housing with 205/50 R16 (Borbet A 7.5) in the front with -35mm H&R springs ???
                  Thanks
                  • Mystikal
                    • 9602
                    #6504
                    All around. Nothing wider is going to work in the rear.
                    • Mystikal
                      • 9602
                      #6505
                      Yes. Back in the day Tirerack used to sell a 16x8.5 +17 Kosei K1 that worked fine even with 245s, that's my best reference point.
                      • Mystikal
                        • 9602
                        #6506
                        You will have to roll your fenders with the rear spacers. 205/45 or 215/40.
                        • Mystikal
                          • 9602
                          #6507
                          Thanks
                          Depends on the offset of the wheels.
                          • badnerd
                            • May 2008
                            • 65
                            #6508
                            ok thanks.....I guess i'll just go back to my old set up
                            Thanks to Mystikal for the help... He assisted in gettin me the look i desired
                            sorry for the crappy cell pics
                            IE 3 springs, all pads removed
                            powerflex offset lcab
                            16 x 8 all around
                            205/45/16 front (i think i need to roll)
                            225/45/16 rear with 15mm rear spacer (rolled fender)
                            • e34_spangler
                              • Dec 2012
                              • 311
                              #6509
                              Ok so I was looking to lower my e30 I had my e34 lowered so I know the basics. I was looking at diamond racing steelies. I was thinking 16x7 but 15s would be much cheaper what are yiy guys thinking?
                              Sent from my SCH-I535 using Tapatalk 2
                              • weew379
                                • Mar 2013
                                • 68
                                #6510
                                215/40 16x9 ET15 front 8mm spacers
                                215/40 16x9 ET15 rear no spacers
                                will they fit without rolling my fenders now?
                                Thanks
