This is a sticky topic.
  • ST1G
    • Oct 2012
    • 6689
    #6616
    Originally posted by Mystikal
    225/45/15 is probably perfect. 225/50 works too.
    Do you think I'll need to roll the fenders?
    • Mystikal
      Wheel Fitment Expert
      • 9602
      #6617
      Definitely not with 225/45s. Small chance with the 225/50s if you really slam it later.
      • 3sge
        • May 2013
        • 28
        #6618
        I have an opportunity to get ASA revolution for really cheap but I'm not sure 17x7 with 42 offset will work on my 92 convertible. I'm on stock suspension
        • Mystikal
          • 9602
          #6619
          They could work with like 20mm spacers. I wouldn't bother though.
          • White325is
            • Oct 2006
            • 5947
            #6620
            17x8 et35. Late model coupe. Looking for flush fit. Not worried about rolling and pulling. On ground control coils with chopped housings.
            • UserError
              • 86
              #6621
              Building an autocross car, planning on running Direzza ZIIs 225/45-16 on 16x8, ET20-25. Would I need fender flares, or can I get by with just an aggressive roll and pull?
              • lambo
                Captain Scene Points
                • 10953
                #6622
                I'm genuinely interested in this as well...
                • cmcilensek
                  • Mar 2013
                  • 40
                  #6623
                  My car is lowered on 16x8.5 et32 salad shooters and I am pretty much rub-free. The tires are 205/40.
                  I want to put on 16x8 et23 style 5s with a little less of a stretch and minimal rubbing.
                  Which tire size should I do and are any spacers recommended?
                  205/40
                  205/45
                  215/40 ---Personal favorite for meatiness
                  • cmcilensek
                    • Mar 2013
                    • 40
                    #6624
                    Bump because I'm ordering tomorrow
                    • Mystikal
                      • 9602
                      #6625
                      Massive spacing needed. 25mm front 30mm rear would begin to get you close to flush.
                      • Mystikal
                        • 9602
                        #6626
                        Just a roll.
                        • Mystikal
                          • 9602
                          #6627
                          205/40
                          205/45
                          205/45 will look meatier/less stretched than 215/40, trust me.
                          You will need ~5mm spacers to clear the front calipers. Search around for info.
                          • Tom.
                            • Sep 2012
                            • 121
                            #6628
                            I just picked up some 15x7 et20 wheels. fronts don't clear the caliper, so I know I'll need spacers there. I'm still undecided on tire size, I just run FK lowering springs and KYB struts.
                            is this a forgiving offset? seems like my options on tires are 205/50, 205/55, or 225/50?
                            anyone have any input at all on potential wheel gap, or spacer recommendations?
                            • dubtechnic
                              • Aug 2012
                              • 63
                              #6629
                              I've been thinking of picking up a set of e38 style 5's. 16x8 et 23. Not sure what tire combo to run yet although I don't plan on having anything stretched. Car is going to be on Koni adjustables and h&r sports. It's an mtech2 92' 325i vert. I've been on the white stock weaves for a while now and wanting to get into a wide size wheel. Recommendations on a sport/street setup with these wheels?
                              • e30lyf
                                • May 2007
                                • 4516
                                #6630
                                Hi!
                                16x9 et15 square set up with IE3,Koni & Drop hats. I am getting coilover anytime soon.
                                what tire size would you recommend for late model? appreciated
                                Thanks,
                                - Fercy -
                                Classic BMW Specialists
                                Santa Clarita, CA
                                www.BimmerHeads.com
