Originally posted by asuj158
View Post
This is a sticky topic.
Originally posted by mpowerful View PostHi Mystikal,
I have spent about 20 hours of my life in this thread and have seen lots of good information so thanks already for that.
What I want to know now is a more of your subjective opinion on my setup.
Ordered RS reps in 16x8 +20 front and 16x9 +20 rear
Tires 205/50/16 nankangs all around
I also have some 5mm spacers I can put in the rear
My car is an 1989 vert with hard and soft top on H&R OE sports, 1 spring pad pulled in rear, and e90 hats in front.
I have not seen a lot of people run the 205/50 front and rear and wondering is going to look ok. I have spent the last few hours researching this and I gather that it will work fine I just want to know if it will look silly compared to say 205/45 fr and 215/45 rear which seems more popular (and far more expensive tire wise). Choosing the 50 sidewall was a bit of a practical gamble for me because I live in uptown new orleans and the streets are unbelievably bad, so I figure a little more tire height would help with comfort level of car. My civic running 195/45 on 7.5 inch rims beats me to death.
Cool thanks man. How much lower do you think i could get away with using the 50 series tires. I could pull a spring pad i the rear (~5mm) and lop half or whole coil in front (1/4-1/2 inch). Then i gotta start worrying about tire hitting well/fenders up high? I have a skidplate so im safe down low.
Originally posted by mpowerful View PostCool thanks man. How much lower do you think i could get away with using the 50 series tires. I could pull a spring pad i the rear (~5mm) and lop half or whole coil in front (1/4-1/2 inch). Then i gotta start worrying about tire hitting well/fenders up high? I have a skidplate so im safe down low.
Originally posted by colombacho View PostQuick q,
did search, but still unclear.
16" kopi +5mm spacer + rear = vibration?
reason is for pure looks. flushness not hella flush
thanks
Mystikal. I lub you. Turned out perfect. I did have a biath of a time seating those 205s on the 9 inch wheels. Fire just ended with singed arm hair so i used a piece of rubber sheet rolled up and held down on tire/bead. Kinda like bike tube method. Even that took me a little while to get right and actually be able to pull it out in time so tire didnt pinch it. Anyway.
Originally posted by mattewhite30 View PostIs it possible to fit this setup with adaptors of course or is it way to big for e30?
(Btw these are the Z3 M wheels)
I'm shooting for as much tire + grip as possible.
17x7.5 ET41
17x9 ET8
5X120
72.6 mm centerbore
225/45-17 F
255/40-17 R
