This is a sticky topic.
  • achtunge30
    • Apr 2006
    • 1029
    #6781
    Originally posted by Mystikal
    Put the 215/45s on the rears and buy 205/45s for the fronts. You'll probably add front spacers later to even out the fitment.
    Thank you Mystikal!
    - Frank
    '87 325ic M-Tech 1 For Sale!
    http://r3vlimited.com/board/showthread.php?t=407503
    Build Thread http://www.r3vlimited.com/board/showthread.php?t=229347
    • Pseudonyms
      • Mar 2012
      • 141
      #6782
      Yes, it will clear the struts.
      Thank you my dude B)
      • Cephas
        • Apr 2012
        • 878
        #6783
        Have a line on borbet type t's. 15x7 et35.
        Do they need spacers to clear in the front?
        • mattewhite30
          • Jan 2011
          • 125
          #6784
          17x8 +25 235/40/17
          So something like XXR 527 would be ideal?
          Fitment: 17x8.25 +25 4x100/5x4.5 in 235/40/17 ?
          • Cephas
            • Apr 2012
            • 878
            #6785
            I should add:
            1989 325i
            They are 15x7 et35 and have Toyo Proxes R888's in 205/50 on them.
            • rnw
              • Jun 2011
              • 21
              #6786
              235/45/17 all around. I guess you could downsize the fronts just for looks but I'd strongly suggest not doing that.
              205/45 215/45
              or
              205/40 215/40
              Hi mystikal,
              thank you, i think i prefer the 45 profile.
              if i want more wider, what tire combo you suggest in 45 profile ?
              • Mystikal
                Wheel Fitment Expert
                • 9602
                #6787
                That 1/4" just might mean you'll need a 3mm spacer on the front with a few particularly wide 235s. Other than that, yup.
                • Mystikal
                  • 9602
                  #6788
                  They should just clear without spacers, but would look and fit much better with 15-20mm spacers.
                  • Mystikal
                    • 9602
                    #6789
                    Originally posted by rnw
                    Hi mystikal,
                    Can't.
                    • achtunge30
                      • Apr 2006
                      • 1029
                      #6790
                      Hey Mystikal,
                      Spoke too soon I think. Now that I am searching for 205/45 for front use I can't seem to find a matching tire to my existing 215/45 rear Kumho Ecsta XS. It seems like I may either have to go mismatched tires (read tons of Don't do it as it will result in bad handling characteristics-opinions) so I'm hesitant. The car is a vert so it does not see track duty but I do drive spiritedly on mountain drives and I do drive the car pretty frequently save for winter.
                      With this in mind, do you recommend I go mismatch or not and if so what tire would you suggest in 205/45?
                      Thanks again!
                      - Frank
                      • justin_l_
                        • Jun 2007
                        • 1079
                        #6791
                        Originally posted by justin_l_
                        Suspension
                        M coupe 5 lug front and rear
                        17x8 et 40 wheels
                        Will a 235/40r17 fit ok?
                        Fronts yes, rears will need spacers if you used Z3M axles.
                        Will be using z3m axles. Suggestions on something that will work without spacers? Going on superchargerd s52 e30 so traction is important.
                        • Scallywagon
                          • 1200
                          #6792
                          195/40 F 205/40 R. Lots of fender rolling. S.drive is probably the only tire available anyway.
                          195 is too small, I'll have to make a 205 work somehow.
                          ( f ; _ ; )f
                          • InNeedOfBoost
                            • Aug 2012
                            • 512
                            #6793
                            Running 16x8's 0 offset all around...love the way they sit, but I'm not a fan of stretching tires. I want a little bit of a meaty tire. I have Falken Ziex 612's on the rear in a 225/50 and its a little too much meat in the back. Having trouble finding some 45 sidewalls that aren't R comps.
                            Ideas, opinions
                            1991 318is - Daily/weekend track car.
                            An on-ramp is a terrible thing to waste...
                            • Jozi
                              • 244
                              #6794
                              Will a 225/45 fit on a 16x9.5 ET5 work? I've got the lips on the inside of my arches flattend to the back of the arch lip and the bumps are also flattened.
                              Also, not keen on stretching tires to much and like a bit of meat in them.
                              Alternatively, how about 16x9 et9 with a 225/45?
                              • InNeedOfBoost
                                • Aug 2012
                                • 512
                                #6795
                                Same thing I'm asking, cept I'm on 8in wheels. Looking for a 225/45/16 that's not an R compound.
